我用的是DE2开发板,按照论坛的移植步骤一步一步往下做,没有出现问题 但是,当我将内核和文件系统下载到FLASH之后 从串口观察的的却是: Linux version 2.6.11-uc0 (kjcx03@KJCX02) (gcc version 3.4.1 (Altera Nios II 5.1 b73)) #1 Sat May 26 21:33:53 2007
uClinux/Nios II Altera Nios II support (C) 2004 Microtronix Datacom Ltd. Built 1 zonelists Kernel command line: root=/dev/mtdblock0 ro PID hash table entries: 128 (order: 7, 2048 bytes) Dentry cache hash table entries: 4096 (order: 2, 16384 bytes) Inode-cache hash table entries: 2048 (order: 1, 8192 bytes) Memory available: 6980k/8192k RAM, 0k/0k ROM (867k kernel code, 214k data) /cygdrive/d/altera/kits/nios2_51/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x/mm/slab.c(927): kernel BUG!
/cygdrive/d/altera/kits/nios2_51/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x/mm/slab.c(927): kernel BUG! hc |
