查表法是将一些事先计算好的结果,存储在常量数组中,运行时节省计算开销。例如,
计算字节中位1的个数,
int countBits( unsigned char dat )
static char nBitTab[256] = { 0, 1, 1, 2, 1, 2, 2, 3, 1, ...... };
return nBitTab[dat];
或将字节按位逆序,
unsigned char reverse( unsigned char dat )
static char revTab[256] = { 0x0, 0x80, 0x40, ......};
或计算0~360度的正弦值,
int sin( int ang )
static const int sinV[] = {
/*sin00=*/0, 1144,2287,3430,4572,5712,6850,7987,9121,10252,
/*sin10=*/11380,12505,13626,14742,15855,16962,18064,19161,20252,21336,
/*sin20=*/22415,23486,24550,25607,26656,27697,28729,29753,30767,31772,
/*sin30=*/32768,33754,34729,35693,36647,37590,38521,39441,40348,41243,
/*sin40=*/42126,42995,43852,44695,45525,46341,47143,47930,48703,49461,
/*sin50=*/50203,50931,51643,52339,53020,53684,54332,54963,55578,56175,
/*sin60=*/56756,57319,57865,58393,58903,59396,59870,60326,60764,61183,
/*sin70=*/61584,61966,62328,62672,62997,63303,63589,63856,64104,64332,
/*sin80=*/64540,64729,64898,65048,65177,65287,65376,65446,65496,65526,
/*sin90=*/65536,
if ( 0 <= ang && ang <= 90 )
return sinV[ang];
if ( 90 < ang && ang <= 180 )
return sinV[180-ang];
if ( 180 < ang && ang <= 270 )
return -sinV[ang-180];
if ( 270 < ang && ang < 360 )
return -sinV[360-ang];
return 0;
理论上,y=f(x),x的取值范围为有限种状态,且f(x)有一定运算量时,都可以考虑查表法。
如,前两个例子中x的范围是字节的256个值,第三个例子是0~90度。
运算量方面,sin的运算量大很多,因此更适合查表。另外,自定义查表法还可用定点数代替浮点数,且一般四则运算也不会溢出(定点数范围0~65535),所以进一步节省了浮点的运算量。
有些情况,x取值状态很多,无法直接用查表法,也可基于其中的公共子集进行扩展。
如要计算32位数中位1的个数,可将其拆成4个字节分别计算并求和。
如要计算0.0~90.0的sin值,可再建立一个sin0.1~0.9的常量表,然后用sin(x+y)的公式,如sin50.5=sin(50+0.5)=sin50*cos0.5+cos50+sin0.5。
另外,查表法还用于简化switch/case语句,还可将数据与代码分离。 |
