regfile = "m8def.dat" $crystal = 8000000
$hwstack = 32
$swstack = 10
$framesize = 40
Config Portd = Output '0-6接LED A-G
Config Portb = Output '0,1,2分别接LED共阳8,9,12 5接sound
Config Adc = Single , Prescaler = Auto , Reference = Avcc '2接电位器
Config Timer1 = Timer , Prescale = 256 '8-1us 64-8us 256-32us 1024-128us
若要x拍 / 分钟,每拍的时间tp = 60 / X (秒) = 60000000 / X(微秒)
需要n个计数,n = Tp / 32
Counter1 = 65535 - N
On Timer1 Tim1_isr
Dim J As Integer
Dim V As Word , Oldv As Word , Count As Word
Dim S As Single
Dim Bpm As Byte , Idx As Byte
Dim Ss As String * 3 , Sled As String * 1
Osccal = &HB3
Start Adc
Enable Timer1
Enable Interrupts
Portb = 0
Portd = 0
Oldv = 0
Bpm = 30
Counter1 = 3035
Sound Portb.5 , 15 , 220
Do
V = 0
For J = 1 To 50
V = V + Getadc(2)
Next J
S = V / 50
V = Round(s)
J = V - Oldv
J = Abs(j)
If J > 4 Then
Oldv = V
'计算节拍数 取值范围 30-230拍/分钟
S = V / 1023
S = S * 200
S = S + 30
Bpm = Round(s)
'计算counter1
S = 60000000 / Bpm
S = S / 32
V = Round(s)
Count = 65535 - V
End If
'显示节拍数
Ss = Str(bpm)
Ss = Format(ss , "000")
'显示个位
Sled = Mid(ss , 3 , 1)
Idx = Val(sled)
Portd = Lookup(idx , Leddata )
Portb.0 = 1
Portb.1 = 0
Portb.2 = 0
Waitms 5
'显示十位
Sled = Mid(ss , 2 , 1)
Idx = Val(sled)
Portd = Lookup(idx , Leddata)
Portb.0 = 0
Portb.1 = 1
Portb.2 = 0
Waitms 5
'显示百位
Sled = Mid(ss , 1 , 1)
Idx = Val(sled)
If Idx = 0 Then
Portb = 0
Else
Portb.0 = 0
Portb.1 = 0
Portb.2 = 1
End If
Loop
End
Tim1_isr:
Counter1 = Count
Sound Portb.5 , 20 , 220
Return
'LED数字 (0-9)
Leddata:
Data &B11000000 , &B11111001 , &B10100100 , &B10110000 , &B10011001
Data &B10010010 , &B10000010 , &B11111000 , &B10000000 , &B10010000
关键字:M8 电子节拍器 |
