如何算定时,怎么看? // File: loopback.v // Date: 01/01/2005 // Name: Eric Crabill // // This is the top level design for the // EE178 Lab #4 assignment. It needs a // bit of work; search for <FILL_IN> and // find out what you should replace it // with to make the design work right... // The `timescale directive specifies what // the simulation time units are (1 ns here) // and what the simulator timestep should be // (1 ps here). `timescale 1 ns / 1 ps module loopback(clk, rst, leds, switches, rs232_tx, rs232_rx, lock); input clk, rst; output [7:0] leds; input [7:0] switches; input rs232_rx; output rs232_tx; output lock; // Instantiate PicoBlaze and the instruction // ROM. This is simply cut and paste from the // example designs that come with PicoBlaze. // Interrupts are not used for this design. wire [9:0] address; wire [17:0] instruction; wire [7:0] port_id; wire [7:0] out_port; reg [7:0] in_port; wire write_strobe; wire read_strobe; wire rst_in; // DCM Signals wire clk55MHz; assign rst_in = rst; kcpsm3 my_kcpsm3 ( .address(address), .instruction(instruction), .port_id(port_id), .write_strobe(write_strobe), .out_port(out_port), .read_strobe(read_strobe), .in_port(in_port), .interrupt(1'b0), .interrupt_ack(), .reset(rst_in), .clk(clk55MHz) ); program my_program ( .address(address), .instruction(instruction), .clk(clk55MHz) ); my_dcm instance_name ( .CLKIN_IN(clk), .RST_IN(rst_in), .CLKFX_OUT(clk55MHz), .CLKIN_IBUFG_OUT(), .CLK0_OUT(), .LOCKED_OUT(lock) ); // Implement the 16x bit rate counter // for the uart transmit and receive. // The system clock is 50 MHz, and the // desired baud rate is 9600. I used // the formula in the documentation to // calculate the terminal count value. reg [8:0] baud_count; reg en_16_x_baud; always @(posedge clk55MHz or posedge rst_in) begin if (rst_in) begin baud_count <= 0; en_16_x_baud <= 0; end else begin if (baud_count == 89) begin baud_count <= 0; en_16_x_baud <= 1; end else begin baud_count <= baud_count + 1; en_16_x_baud <= 0; end end end // Implement the output port logic: // leds_out, port 01 // uart_data_tx, port 03 wire write_to_uart; wire write_to_leds; wire buffer_full; reg [7:0] leds; assign write_to_uart = write_strobe & (port_id == 8'h03); assign write_to_leds = write_strobe & (port_id == 8'h01); always @(posedge clk55MHz or posedge rst_in) begin if (rst_in) leds <= 0; else if (write_to_leds) leds <= out_port; end uart_tx transmit ( .data_in(out_port), .write_buffer(write_to_uart), .reset_buffer(rst_in), .en_16_x_baud(en_16_x_baud), .serial_out(rs232_tx), .buffer_full(buffer_full), .buffer_half_full(), .clk(clk55MHz) ); // Implement the input port logic: // switch_in, port 00 // uart_data_rx, port 02 // data_present, port 04 // buffer_full, port 05 reg read_from_uart; wire [7:0] rx_data; wire data_present; always @(posedge clk55MHz or posedge rst_in) begin if (rst_in) begin in_port <= 0; read_from_uart <= 0; end else begin case (port_id) 8'h00: in_port <= switches; 8'h02: in_port <= rx_data; 8'h04: in_port <= {7'b0000000, data_present}; 8'h05: in_port <= {7'b0000000, buffer_full}; default: in_port <= 8'h00; endcase read_from_uart <= read_strobe & (port_id == 8'h02); end end uart_rx receive ( .serial_in(rs232_rx), .data_out(rx_data), .read_buffer(read_from_uart), .reset_buffer(rst_in), .en_16_x_baud(en_16_x_baud), .buffer_data_present(data_present), .buffer_full(), .buffer_half_full(), .clk(clk55MHz) ); endmodule 这样一个程序,它的定时是怎么算的? |
