摘要
我们在这里讨论的是对嵌入式linux系统的启动过程的输出信息的注释,通过我们的讨论,大家会对嵌入式linux启动过程中出现的、以前感觉熟悉的、但却又似是而非的东西有一个确切的了解,并且能了解到这些输出信息的来龙去脉。
嵌入式linux的启动信息是一个很值得我们去好好研究的东西,它能将一幅缩影图呈现在我们面前,来指导我们更加深入地理解linux内核。
关键字:linux,嵌入式,启动,bootloader
正文
作为一名嵌入系统开发者,你一定遇到过下面的情景:
在某论坛上看到一篇帖子,上面贴着嵌入式linux开发板启动时的有关信息,然后大家在帖子里讨论着这个启动过程中出现的问题,随机举例如下:
Linux version 2.4.20-uc0 (root@Local) (gcc version 2.95.3
20010315 (release)(ColdFire patches - 20010318 from http://f
(uClinux XIP and shared lib patches from http://www.snapgear.com/)) #20 三 6月 1
8 00:58:31 CST 2003
Processor: Samsung S3C4510B revision 6
Architecture: SNDS100
On node 0 totalpages: 4096
zone(0): 0 pages.
zone(1): 4096 pages.
zone(2): 0 pages.
Kernel command line: root=/dev/rom0
Calibrating delay loop... 49.76 BogoMIPS
Memory: 16MB = 16MB total
Memory: 14348KB available (1615K code, 156K data, 40K init)
Dentry cache hash table entries: 2048 (order: 2, 16384 bytes)
Inode cache hash table entries: 1024 (order: 1,
Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
Buffer-cache hash table entries: 1024 (order: 0, 4096 bytes)
Page-cache hash table entries: 4096 (order: 2, 16384 bytes)
POSIX conformance testing by UNIFIX
Linux NET4.0 for Linux 2.4
Based upon Swansea University Computer Society NET3.039
Initializing RT netlink socket
Starting kswapd
Samsung S3C4510 Serial driver version 0.9 (2001-12-27) with no serial options en
abled
ttyS00 at 0x3ffd000 (irq = 5) is a S3C4510B
ttyS01 at 0x3ffe000 (irq = 7) is a S3C451
Blkmem copyright 1998,1999 D. Jeff Dionne
Blkmem copyright 1998 Kenneth Albanowski
Blkmem 1 disk images:
0: BE558-1A5D57 [VIRTUAL BE558-1A5D57] (RO)
RAMDISK driver initialized: 16 RAM disks of 1024K size 1024 blocksize
Samsung S3C4510 Ethernet driver version 0.1 (2002-02-20) <mac@os.nctu.edu.tw>
eth0: 00:40:95:36:35:34
NET4: Linux TCP/IP 1.0 for NET4.0
IP Protocols: ICMP, UDP, TCP
IP: routing cache hash table of 512 buckets, 4Kbytes
TCP: Hash tables configured (established 1024 bind 1024)
VFS: Mounted root (romfs
Freeing init memory: 40K
上面的这些输出信息,也可能包括你自己正在做的嵌入式linux开发板的输出信息,其中的每一行,每一个字的含义,你是否深究过,或者说大部分的含义你能确切地知道的?本人想在这里结合本人在实践中一些体会来和广大嵌入式linux的开发者一起读懂这些信息。
我们在这里将以一个真实的嵌入式linux系统的启动过程为例,来分析这些输出信息。启动信息的原始内容将用标记标出,以区别与注释。
嵌入式linux的启动主要分为两个阶段:
①
第一部分bootloader启动阶段
②
第二部分linux 内核初始化和启动阶段
第一节:start_kernel
第二节:用户模式( user_mode )开始,start_kernel结束
第三节:加载linux内核完毕,转入cpu_idle进程
第一部分 : bootloader启动
Boot loader v0.12
NOTE: this boot loader is designed to boot kernels made with the
2.4.xx releases
bootloader for XV
Built at Nov 20 2005 10:12:35
Bootloader头信息,版本,编译时间等,这个因不同的bootloader的设计而有所不同,由此你能看出bootloader的版本信息,有很多使用的是通用的bootloader,如u-boot,redboot等。
将bootloader加载到内存ram中的0x90060000处,即将bootloader加载到内存的高端地址处。
Linux内核将被bootloader加载到0x90090000处。
查找到了启动boot的配置信息
Booted from parallel flash
从flash中启动代码,此处的flash为并行闪存。Flash的分类列举如下:
闪存分三类:并行,串行,不可擦除。
①并行Parallel flash
NOR Flash,Intel于1988年发明.随机读取的速度比较快,随机按字节写,每次可以传输8Bit。一般适合应用于数据/程序的存贮应用中.NOR还可以片内执行(execute-in-place)XIP.写入和擦除速度很低。
NAND Flash,1989年,东芝公司发明.是以块和页为单位来读写的,不能随机访问某个指定的点.因而相对来说读取速度较慢,而擦除和写入的速度则比较快,每次可以传输16Bit,一般适用在大容量的多媒体应用中,容量大。如:CF,SM.
②串行Serial Flash 是以字节进行传输的,每次可以传输1-2Bit.如:MMC,SD,MS卡.串行闪存器件体积小,引脚也少,成本相对也更低廉。
③不可擦除Mask Rom Flash的特点是一次性录入数据,具有不可更改性,经常运用于游戏和需版权保护文件等的录入。其显著特点是成本低。
注意:任何flash器件的写入操作只能在空或已擦除的单元内进行,所以大多数情况下,在进行写入操作之前必须先执行擦除。NAND器件执行擦除操作是十分简单的,而NOR则要求在进行擦除前先要将目标块内所有的位都写为0。 |
