安装Altera MegaCore IP Library 6.0出错
![Rank: 3](images/default/star_level2.gif) ![Rank: 3](images/default/star_level1.gif)
我在安装Altera MegaCore IP Library(6.0版)时出现以下错误,请高手帮忙看看是怎么回事,万分感谢! Setup has experienced an error. Please do the following: - Close any running programs - Empty your temporary folder - Check your Internet connection (Internet-based Setups) Then try to run the Setup again. Error Code: -6001 |
Setup has experienced an error. 没有装起,如果不行,就和系统有关了。 |
这个版主不太冷
我的中电网博客:http://blog.chinaecnet.com/u/20/index.htm |
