LX9通过Master SPI 方式配置数据遇到问题
使用spartan 6 xc6slx9 使用SPI方式的FLASH做PROM,使用impact通过 FPGA对SPI FLASH进行烧写,可以查出SPI FLASH,但是烧写配置文件时(.mcs)时,进行至7%时停止了,然后提示编程失败。
FPGA的DONE输出端口接了300Ω上拉,其余和数据手持基本一致。
信息输出提示如下:
'1': Programming Flash.
'1': Reading device contents...
done.
'1': Verification completed.
'1'rogramming in x1 mode.
S25FL064P Status Register Contents = 0x0000.
QUAD ENABLE                                       :         0
STATUS REGISTER PROTECT 1                         :         0
STATUS REGISTER PROTECT 0                         :         0
SECTOR PROTECT                                    :         0
TOP/BOTTOM PROTECT                                :         0
BLOCK PROTECT BIT 2                               :         0
BLOCK PROTECT BIT 1                               :         0
BLOCK PROTECT BIT 0                               :         0
'1': Configuration data download to FPGA was not successful. DONE did not go high, please check your configuration setup and mode settings.
INFO:iMPACT - '1': Flash was not programmed successfully.
PROGRESS_END - End Operation.
Elapsed time =    112 sec.
