CPLD程序在综合时没有问题,但是在Fit Design的时候常常出现以下错误提醒:Project 'tsmc_newcontroller' could not be partitioned. The location assignments in block M may be too restrictive.
Please check that the pin/node assignments are valid.
这是无法分区,资源不够吗?分区的原理是啥?该如何解决?
无法通过的这个程序,资源使用情况:Simple gate primitives:
DFF 84 uses
IBUF 39 uses
OBUF 59 uses
AND2 445 uses
INV 280 uses
OR2 47 uses
XOR2 18 uses
DLAT 6 uses
Inspect circuit MatrixConverter
Number of input ports : 15
Number of output ports : 11
Number of bidir ports : 0
Number of instances : 995
Number of nets : 1043
但是另一个程序,用同样的芯片,资源使用情况为:
DFF 189 uses
DFFC 12 uses
DFFCRH 16 uses
DFFRH 8 uses
IBUF 57 uses
OBUF 71 uses
AND2 926 uses
INV 642 uses
DLATRH 2 uses
OR2 90 uses
XOR2 30 uses
DLAT 6 uses
Number of input ports : 21
Number of output ports : 15
Number of instances : 2072
Number of nets : 2131
这个程序是可以进行Fit Design的。Fit Design是否通过到底跟什么有关?如何优化程序? |
