» [谁知道这几个晶体管]
[谁知道这几个晶体管]
snowli
1 小时
中级会员
性别
男
snowli
发表于 2003-11-28 12:53
我知道的管子都在下面,请老兄对照参考:
小信号放大、开关三极管
S9011G/H S9012G/H S9013G/H S9014C/D S9018G/H/I SS8050C/D
SS8550C/D C1815GR/Y A1015GR/Y C3198GR/Y A1266GR C945Q/P
A733Q/P 2N5551 2N5401 MPSA42 MPSA92 C3202GR/Y
C3205GR 2N4401 A1048GR C2668GR C380-Y/O C2240Y
C2001Y C3203GR A1273GR 2N4403 C2458GR C2688P
C388GR/Y A950Y C2120Y 2SD965
各种型号之DIP直插二极管
FR153-FR157 FR104-FR107 IN5391-IN5399 KL201-RL207 IN5401-IN5408 IN4001-IN4007
DB3 1W&1/2W稳压管全系列
snowli
1 小时
中级会员
性别
男
2
snowli
发表于 2003-11-28 12:54
肖特基系列
IN5817 IN5818 IN5819 IN5822 MUR3060 RK14
康可(CONCORD)瞬态抑制稳压二极管(TVS)
编带(DIP):P6KE/1.5KE系列
6.8A/CA 20A/CA 56A/CA 160A/CA
7.5A/CA 22A/CA 62A/CA 170A/CA
8.2A/CA 24A/CA 68A/CA 180A/CA
9.1A/CA 27A/CA 75A/CA 200A/CA
10A/CA 30A/CA 82A/CA 220A/CA
11A/CA 33A/CA 91A/CA 250A/CA
12A/CA 36A/CA 100A/CA 300A/CA
13A/CA 39A/CA 110A/CA 350A/CA
15A/CA 43A/CA 120A/CA 400A/CA
16A/CA 47A/CA 130A/CA 440A/CA
18A/CA 51A/CA 150A/CA
编带(DIP):SA和5KP全系列
贴片(SMD):SMBJ/SMCJ全系列
5.0A/CA 14A/CA 36A/CA 78A/CA
6.0A/CA 15A/CA 40A/CA 85A/CA
6.5A/CA 16A/CA 43A/CA 90A/CA
7.0A/CA 17A/CA 45A/CA 100A/CA
7.5A/CA 18A/CA 48A/CA 110A/CA
8.0A/CA 20A/CA 51A/CA 120A/CA
8.5A/CA 22A/CA 54A/CA 130A/CA
9.0A/CA 24A/CA 58A/CA 150A/CA
10A/CA 26A/CA 60A/CA 160A/CA
11A/CA 28A/CA 64A/CA 170A/CA
12A/CA 30A/CA 70A/CA
13A/CA 33A/CA 75A/CA
发光二极管系列
φ3红、绿、黄
φ5红、绿、黄
白发红、白发绿、白发黄
普亮度、高亮度、超高度
整流桥系列
DB104—DB107 W005—W10
RB151—RB157 2W005—2W10
KBP200—KBP208 KBPC300—KBPC310
KBL400—KBL410 KBPC606—KBPC610
KBU600—KBU610 KBPC800—KBPC810
KBU806—KBU810 KBPC1000—KBPC1010
KBPC1500—KBPC1510 KBPC2500—KBPC2510
KBPC3500—KBPC3510 KBPC5000—KBPC50
snowli
1 小时
中级会员
性别
男
3
snowli
发表于 2003-11-28 12:55
贴片三极管
MMBT2222LT1 MMBT8550LT1 BC807-25 NDS356AP 2SC2712LG、LL
MMBT2907LT1 MMBTA42LT1 BC807-40 KTC3265 2SC2714QY、QL
MMBT3904LT1 MMBTA92LT1 BC817-25 KTC1504 2SA812(M5、M6、M7)
MMBT3906LT1 MMBTA13LT1
BC817-40 KTC3880 2SC1623(L5、L6、L7)
MMBT4401LT1 MMBTH10LT1 BAS16LT1 KTC3875 2SC3356(R24、R25)
MMBT4403LT1 MMBT914LT1 BAV70LT1 2N7002LT1 2SC4226(R24、R25)
MMBT5401LT1 MMBT918LT1 BAV99LT1 ISS355TE-17 2SC3585(R24、R25)
MMBT5551LT1 BC846B、C BAW56LT1 2SC2734 2SD596(DV3、DV4、DV5)
MMBT90系列 BC847B、C BAT54LT1 2SC2412 2SB624(BV3、BV4、BV5)
MMBT8050LT1 BC848B、C ISS181 2S1162GR
1W小功率对管系列
H5609 H5610 C2655 C2229 C1384 C2328
C2235 C2383 C3205 C2500 D647 B647
A1020 A966 A684 A928 A965 A1013
A1273 A1162
达林顿系列
TIP41C TIP42C TIP31C TIP32C TIP122 TIP127
KSP13 TIP142 TIP147 TIP105 TIP112
Pcw≥10W中功率对管
B772 B647 B649 A940 B834 A1301
D882 D667 D669 C2073 D880 C3280
三端稳压系列
LM78L05 LM78L12 LM78L15 LM336 LM7805 LM7808
LM7812 LM7824 LM7905 LM7912 LM431 LM385
LM317 78M05 LM317(TO-92封装)
snowli
1 小时
中级会员
性别
男
4
snowli
可控硅
CR02AM CR03AM BCR1AM MCR100-6 MCR100-8 97A6
94A4 97A8 BTA04 BTA06 BTA08 BTA12
BTA41 BT151 BT136 BT169D BT137 BT138
DB3(触发管) PCR406(彩灯控制器专用) 2P4M S0806 TL336A
变容管
ISV101 ISV149 SV251 ISV147 IIS2638 BAW62
IN60P BB910 FV1043 IS2236 BAT85 ISV99
snowli
1 小时
中级会员
性别
男
5
snowli
发表于 2003-11-28 12:56
以后请老兄注明是用在什么上的。
txxucong@163.co
该用户已被删除
6
txxucong@163.co
发表于 2004-3-26 10:11
[谁知道这几个晶体管]
晶体管
贴片的三极管上只有这个么几个字符“L7”;“R25”;“DV4”,不知分别是什么样的管子,有没有更好的代替?(L7 在电路中起音频放大及调制之用,R25作射频放大之用。)
还有通常所说的 “红绿管”是什么二极管,有什么特点和功用。请高手指教,谢谢!
xia312@sina.com
该用户已被删除
7
xia312@sina.com
发表于 2004-3-26 10:11
简短一点,问题解决就好了。2SC1623-L6/L7/L5,请参考其DATASHEET.AUDIO FREQUENCY GENERAL PURPOSE AMPLIFIER;2SC3356-R25 NPN EPITAXIAL SILICON RF TRANSISTOR;2SC596-DV3/DV4高频三极管
[此贴子已经被作者于2004-3-26 10:11:27编辑过]
