编译没有报错,但是无.out文件生成,CDT Build Console显示临时文件有错,求大神指导
**** Build of configuration Debug for project SRMC ****
( U$ [$ P4 i' l5 X
"C:\\ti\\ccsv6\\utils\\bin\\gmake" -k all
'Building file: ../main.c'
'Invoking: C2000 Compiler'
"C:/ti/ccsv6/tools/compiler/ti-cgt-c2000_6.4.6/bin/cl2000" -v28 -ml -mt --include_path="C:/ti/ccsv6/tools/compiler/ti-cgt-c2000_6.4.6/include" --include_path="D:/SRMC" --include_path="D:/SRMC/include" --advice:performance=all -g --diag_warning=225 --display_error_number --diag_wrap=off --preproc_with_compile --preproc_dependency="main.pp"  "../main.c"
"C:\Users\CAIHAI~1\AppData\Local\Temp\0762010", ERROR!   at line 343: [E0003] Syntax error - Operand 1
         OUT 1, 000ch$ Y- o* @6 v% @9 g* j
"C:\Users\CAIHAI~1\AppData\Local\Temp\0762010", ERROR!   at line 349: [E0003] Syntax error - Operand 1
         OUT 0, 000ch
2 s) V0 K' N( o/ \4 X" @2 @8 x
2 Assembly Errors, No Assembly Warnings
Errors in Source - Assembler Aborted9 j) T, }: M' g; j' ?
/ O  i; d7 C5 i: K$ c
>> Compilation failure! }! K! \& T% |- s
gmake: *** [main.obj] Error 11 N7 u4 m& m# d8 H# g& g, z
'Building file: ../srm.c'
"C:/ti/ccsv6/tools/compiler/ti-cgt-c2000_6.4.6/bin/cl2000" -v28 -ml -mt --include_path="C:/ti/ccsv6/tools/compiler/ti-cgt-c2000_6.4.6/include" --include_path="D:/SRMC" --include_path="D:/SRMC/include" --advice:performance=all -g --diag_warning=225 --display_error_number --diag_wrap=off --preproc_with_compile --preproc_dependency="srm.pp"  "../srm.c"
'Finished building: ../srm.c'1 c- t2 m6 u0 f* l  Z
' '5 u, Q$ k! D9 W4 ]( n! X8 u4 j
'Building file: ../source/DSP28_Adc.c'% m3 d, U! f& F# ?8 d( c/ {. d* D
'Invoking: C2000 Compiler'$ f  u5 k% l' m( f& U% m+ ~
"C:/ti/ccsv6/tools/compiler/ti-cgt-c2000_6.4.6/bin/cl2000" -v28 -ml -mt --include_path="C:/ti/ccsv6/tools/compiler/ti-cgt-c2000_6.4.6/include" --include_path="D:/SRMC" --include_path="D:/SRMC/include" --advice:performance=all -g --diag_warning=225 --display_error_number --diag_wrap=off --preproc_with_compile --preproc_dependency="source/DSP28_Adc.pp" --obj_directory="source"  "../source/DSP28_Adc.c"1 i; N9 h3 _3 t7 E; X2 h
'Finished building: ../source/DSP28_Adc.c'
' '1 X6 F( v1 @0 y9 \1 i" x
'Building file: ../source/DSP28_DefaultIsr.c'
'Invoking: C2000 Compiler': S, x: p- v9 e  Z" S
"C:/ti/ccsv6/tools/compiler/ti-cgt-c2000_6.4.6/bin/cl2000" -v28 -ml -mt --include_path="C:/ti/ccsv6/tools/compiler/ti-cgt-c2000_6.4.6/include" --include_path="D:/SRMC" --include_path="D:/SRMC/include" --advice:performance=all -g --diag_warning=225 --display_error_number --diag_wrap=off --preproc_with_compile --preproc_dependency="source/DSP28_DefaultIsr.pp" --obj_directory="source"  "../source/DSP28_DefaultIsr.c"
'Finished building: ../source/DSP28_DefaultIsr.c'( `. R! N/ A0 b4 t* j0 I
' '* @! Y- }# v1 g- p/ ^  r- S
'Building file: ../source/DSP28_Ev.c', C+ W4 d8 ^( K* L" s- j
"C:/ti/ccsv6/tools/compiler/ti-cgt-c2000_6.4.6/bin/cl2000" -v28 -ml -mt --include_path="C:/ti/ccsv6/tools/compiler/ti-cgt-c2000_6.4.6/include" --include_path="D:/SRMC" --include_path="D:/SRMC/include" --advice:performance=all -g --diag_warning=225 --display_error_number --diag_wrap=off --preproc_with_compile --preproc_dependency="source/DSP28_Ev.pp" --obj_directory="source"  "../source/DSP28_Ev.c"
'Finished building: ../source/DSP28_Ev.c'
' '$ F! ^! o. m$ c% y1 X
'Building file: ../source/DSP28_GlobalVariableDefs.c'
"C:/ti/ccsv6/tools/compiler/ti-cgt-c2000_6.4.6/bin/cl2000" -v28 -ml -mt --include_path="C:/ti/ccsv6/tools/compiler/ti-cgt-c2000_6.4.6/include" --include_path="D:/SRMC" --include_path="D:/SRMC/include" --advice:performance=all -g --diag_warning=225 --display_error_number --diag_wrap=off --preproc_with_compile --preproc_dependency="source/DSP28_GlobalVariableDefs.pp" --obj_directory="source"  "../source/DSP28_GlobalVariableDefs.c"! C7 @0 _0 m3 V2 C/ h
'Finished building: ../source/DSP28_GlobalVariableDefs.c'/ H, t. ]+ C$ V9 ?! G
' '( A3 w7 {% J8 K# L: H+ X" |" o; ]
'Building file: ../source/DSP28_Gpio.c'
'Invoking: C2000 Compiler'$ {& F* J$ R7 s
"C:/ti/ccsv6/tools/compiler/ti-cgt-c2000_6.4.6/bin/cl2000" -v28 -ml -mt --include_path="C:/ti/ccsv6/tools/compiler/ti-cgt-c2000_6.4.6/include" --include_path="D:/SRMC" --include_path="D:/SRMC/include" --advice:performance=all -g --diag_warning=225 --display_error_number --diag_wrap=off --preproc_with_compile --preproc_dependency="source/DSP28_Gpio.pp" --obj_directory="source"  "../source/DSP28_Gpio.c"
'Finished building: ../source/DSP28_Gpio.c'3 \8 |: K" F0 G! Q0 B" C
'Building file: ../source/DSP28_InitPeripherals.c'5 ~7 L5 E1 U& j0 b( X* Y
'Invoking: C2000 Compiler'+ }" V! T% Q2 Z: C
"C:/ti/ccsv6/tools/compiler/ti-cgt-c2000_6.4.6/bin/cl2000" -v28 -ml -mt --include_path="C:/ti/ccsv6/tools/compiler/ti-cgt-c2000_6.4.6/include" --include_path="D:/SRMC" --include_path="D:/SRMC/include" --advice:performance=all -g --diag_warning=225 --display_error_number --diag_wrap=off --preproc_with_compile --preproc_dependency="source/DSP28_InitPeripherals.pp" --obj_directory="source"  "../source/DSP28_InitPeripherals.c"0 D3 b% ^6 n* h8 t0 z' |
'Finished building: ../source/DSP28_InitPeripherals.c'
' '/ E, w+ V, i' _9 R% e/ }
'Building file: ../source/DSP28_PieCtrl.c'2 m5 ]1 x7 I# s: B% l2 h" \  A
"C:/ti/ccsv6/tools/compiler/ti-cgt-c2000_6.4.6/bin/cl2000" -v28 -ml -mt --include_path="C:/ti/ccsv6/tools/compiler/ti-cgt-c2000_6.4.6/include" --include_path="D:/SRMC" --include_path="D:/SRMC/include" --advice:performance=all -g --diag_warning=225 --display_error_number --diag_wrap=off --preproc_with_compile --preproc_dependency="source/DSP28_PieCtrl.pp" --obj_directory="source"  "../source/DSP28_PieCtrl.c"
'Finished building: ../source/DSP28_PieCtrl.c'; u  E' u8 K
