ARM 11 裸奔之一 LED循环点亮
ARM 11 裸奔之一 LED循环点亮
nit.s  ; 注:  IMPORT 之前需要有一个空格,否则编译不能通过 IMPORT Main
     AREA |C$$code|,CODE,READONLY
     global        start
start
     bl         Main
     END
main.c
#include
#define rGPMCON                     (*(volatile unsigned*)(0x7F008820))
#define rGPMDAT                     (*(volatile unsigned*)(0x7F008824))
#define rGPMPUD                     (*(volatile unsigned*)(0x7F008828))
void msDelay(int time)
           volatile unsigned int i,j;
           for(i=0;i<2000000;i++)
                 for(j=0;j<time;j++); }
void GPIO_Init(void)
     rGPMCON =0x11111;
     rGPMPUD =0x00;
     rGPMDAT =0X1F;
void LedTest(void)
     volatile unsigned int i;
     while(1)
         for(i=0;i<4;i++)
              rGPMDAT = ~(1<<i);               msDelay(10);
void Main(void)
     GPIO_Init();
     LedTest();
备注:程序跑通。LED循环点亮
</i);
</time;j++);
