RC522模块原理图与PCB图,包括51单片机和430单片机测试程序
51单片机测程序:
  • #include "lpcreg.h"
  • #include "main.h"
  • #include "mfrc522.h"
  • unsigned char code data1[16] = {0x12,0x34,0x56,0x78,0xED,0xCB,0xA9,0x87,0x12,0x34,0x56,0x78,0x01,0xFE,0x01,0xFE};
  • //M1卡的某一块写为如下格式,则该块为钱包,可接收扣款和充值命令
  • //4字节金额(低字节在前)+4字节金额取反+4字节金额+1字节块地址+1字节块地址取反+1字节块地址+1字节块地址取反
  • unsigned char code data2[4]  = {0x12,0,0,0};
  • unsigned char code DefaultKey[6] = {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF};
  • unsigned char g_ucTempbuf[20];
  • void main( )
  •      unsigned char status;
  •      InitializeSystem( );
  •      PcdReset();
  •      PcdAntennaOff(); //关闭天线
  •      PcdAntennaOn();  //开启天线
  •      while ( 1 )
  •          status = PcdRequest(PICC_REQALL, g_ucTempbuf);       #define PICC_REQIDL 0x26    //寻天线区内未进入休眠状态
  •          if (status != MI_OK)
  •               LED_GREEN = 1;
  •               continue;
  •          LED_GREEN = 0;
  •          status = PcdAnticoll(g_ucTempbuf);
  •              continue;
  •          status = PcdSelect(g_ucTempbuf);
  •             continue;
  •          status = PcdAuthState(PICC_AUTHENT1A, 1, DefaultKey, g_ucTempbuf);
  •              continue;
  •          status = PcdWrite(1, data1);
  •             continue;
  •          status = PcdValue(PICC_DECREMENT,1,data2);
  •            continue;
  •          status = PcdBakValue(1, 2);
  •              continue;
  •          status = PcdRead(2, g_ucTempbuf);
  •             continue;
  •           PcdHalt();   //命令卡片进入休眠状态
  • //系统初始化
  • void InitializeSystem()
  •     P0M1 = 0x0; P0M2 = 0x0;
  •     P1M1 = 0x0;        P1M2 = 0x0;
  •     P3M1 = 0x0; P3M2 = 0xFF;
  •     P0 = 0xFF; P1 = 0xFF; P3 = 0xFF;
  • //功    能:复位RC522
  • //返    回: 成功返回MI_OK
  • char PcdReset(void)
  •     MF522_RST=1;
  •     _nop_();
  •     MF522_RST=0;
  •     _nop_();
  •     MF522_RST=1;
  •      _nop_();
  •     WriteRawRC(CommandReg,PCD_RESETPHASE);
  •     _nop_();
  •     WriteRawRC(ModeReg,0x3D);            //和Mifare卡通讯,CRC初始值0x6363
  •     WriteRawRC(TReloadRegL,30);
  •     WriteRawRC(TReloadRegH,0);
  •     WriteRawRC(TModeReg,0x8D);
  •     WriteRawRC(TPrescalerReg,0x3E);
  •     return MI_OK;
  • //功    能:写RC632寄存器
  • //参数说明:Address[IN]:寄存器地址
  • //          value[IN]:写入的值
  • void WriteRawRC(unsigned char Address, unsigned char value)
  •     unsigned char i, ucAddr;
  •     MF522_SCK = 0;
  •     MF522_NSS = 0;
  •     ucAddr = ((Address<<1)&0x7E);
  •     for(i=8;i>0;i--)
  •         MF522_SI = ((ucAddr&0x80)==0x80);
  •         MF522_SCK = 1;
  •         ucAddr <<= 1;
  •         MF522_SCK = 0;
  •     for(i=8;i>0;i--)
  •         MF522_SI = ((value&0x80)==0x80);
  •         MF522_SCK = 1;
  •         value <<= 1;
[/tr]
