stm32串行控制lcd12864液晶显示器 程序
手里有一块12864的液晶显示器,今天拿起来用stm32F103做了一个工程,方便大家参考,希望对大家能够有用。PDF文档仅共参考,我使用的LCD的核心与pdf上的有所不同。
  • #include "12864.h"
  • GPIO_InitTypeDef GPIO_InitStructure;
  • void Delay(__IO uint32_t nCount)
  •    for(; nCount != 0; nCount--);
  • void send_dat(unsigned char dat)
  •     unsigned char i;
  •         //GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  •     for(i=0;i<8;i++)
  •                 if((dat&0x80)==0x80) SID_1;
  •                 if((dat&0x80)==0x00) SID_0;
  •         CLK_0;
  •                 Delay(35);
  •         CLK_1;
  •                 dat<<=1;
  • unsigned char get_byte()
  •      unsigned char i,temp1=0,temp2=0;
  •          //GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
  •      for(i=0;i<8;i++)
  •            temp1=temp1<<1;
  •            CLK_0;
  •                    Delay(25);
  •            CLK_1;
  •                    Delay(20);
  •            CLK_0;
  •            if(GPIO_ReadOutputDataBit(GPIOE,GPIO_Pin_3)) temp1++;
  •      for(i=0;i<8;i++)
  •            temp2=temp2<<1;
  •            CLK_0;
  •                    Delay(25);
  •            CLK_1;
  •                    Delay(25);
  •            CLK_0;
  •            if(GPIO_ReadOutputDataBit(GPIOE,GPIO_Pin_3))  temp2++;
  •      return ((0xf0&temp1)+(0x0f&temp2));
  • void check_busy()
  •     do
  •         send_dat(0xfc);
  •     while((get_byte()&0x8000)==0x8000);
  • void send_cmd(unsigned char cmd)
  •     check_busy();
  •     send_dat(0xf8);    //
  •     send_dat(cmd&0xf0); //
  •     send_dat((cmd&0x0f)<<4); //
  • void write_char(unsigned char dat)
  •     check_busy();
  •     send_dat(0xfa);//rw=0;rs=1
  •     send_dat(dat&0xf0);
  •     send_dat((dat&0x0f)<<4);
  • void lcd_clear()        //清除显示
  •     send_cmd(0x01);
  • void lcd_pos(unsigned char y_add , unsigned char x_add)
  •     switch(y_add)
  •         case 1:
  •         send_cmd(0X80|x_add);break;
  •         case 2:
  •         send_cmd(0X90|x_add);break;
  •         case 3:
  •         send_cmd(0X88|x_add);break;
  •         case 4:
  •         send_cmd(0X98|x_add);break;
  •         default:break;
  • void lcd_wstr(unsigned char y_add , unsigned char x_add , unsigned char *str)    //
  •     unsigned char i;
  •     lcd_pos(y_add , x_add);
  •     for(i=0;str!='\0';i++)
  •         write_char(str);
  • void write_figer(unsigned char y_add , unsigned char x_add , unsigned int figer)//在任何位置写数字
  •     unsigned char d[5],i,j;
  •     d[4]=figer%10;
  •     d[3]=figer%100/10;
  •     d[2]=figer%1000/100;
  •     d[1]=figer%10000/1000;
  •     d[0]=figer/10000;
  •     for(i=0;i<5;i++)
  •         if(d!=0)break;
  •     if(i==5)i--;
  •     if(i==4)send_dat(0x30);//数据装完,准备发送
  •     for(j=i;j<5;j++)
  •        send_dat(d[j]|0x30);//取得的数字加上0x30也即得到该数字的ASCII码,再将该数字发送去显示
  • void lcd_init()     //
  •     Delay(0xfff);
  •     send_cmd(0x30);
  •     send_cmd(0x0C);//0000,1100 整体显示,游标off,游标位置off
  •     send_cmd(0x01);//0000,0001 清DDRAM
  •     send_cmd(0x02);//0000,0010 DDRAM地址归位
  •     send_cmd(0x80);//1000,0000 设定DDRAM 7位地址000,0000到地址计数器A
  • /******************* (C) COPYRIGHT 2011 奋斗STM32 *****END OF FILE****/
复制代码
