Windows共享内存可以让两个进程对同一块内存进行读写。
以下有2个进程,a.cpp生成A进程,b.cpp生成b进程。那么a进程将不停地读名为"Global\\MyFileMappingObject"的共享内存块,而b进程不停地写名为"Global\\MyFileMappingObject"的共享内存块。从而实现IPC。
复制代码
//a.cpp
#include <windows.h>
#include <string.h>
#include <string>
#include <iostream>
#include <tchar.h>
using namespace std;
#define BUF_SIZE 256
TCHAR szName[]=TEXT("Global\\MyFileMappingObject"); //指向同一块共享内存的名字
int main(int argc, char *argv[])
HANDLE hMapFile;
LPCTSTR pBuf;
hMapFile = CreateFileMapping(
INVALID_HANDLE_VALUE, // use paging file
NULL, // default security
PAGE_READWRITE, // read/write access
0, // maximum object size (high-order DWORD)
BUF_SIZE, // maximum object size (low-order DWORD)
szName); // name of mapping object
if (hMapFile == NULL)
_tprintf(TEXT("Could not create file mapping object (%d).\n"),
GetLastError());
return 1;
pBuf = (LPTSTR) MapViewOfFile(hMapFile, // handle to map object
FILE_MAP_ALL_ACCESS, // read/write permission
0,
0,
BUF_SIZE);
if (pBuf == NULL)
_tprintf(TEXT("Could not map view of file (%d).\n"),
GetLastError());
CloseHandle(hMapFile);
return 1;
//从main开始至此,A B process代码一样,都是获取名为"Global\\MyFileMappingObject"的共享内存的指针
//以下代码,A不停地读共享内存pBuf
while(1)
cout<<pBuf<<endl;
cout<<"A process: hit keyboard to receive from B process"<<endl;
getchar();
UnmapViewOfFile(pBuf);
return 0;
复制代码
复制代码
//b.cpp
#include <iostream>
#include <Windows.h>
#include <tchar.h>
int main()
HANDLE hMapFile;
LPCTSTR pBuf;
GetLastError());
return 1;
0,
0,
BUF_SIZE);
if (pBuf == NULL)
GetLastError());
return 1;
//以下代码,B不停写共享内存pBuf
while(1)
TCHAR s[BUF_SIZE];
cout<<"B process: plz input sth. to be transfered to A process."<<endl;
cin>>s;
memcpy((PVOID)pBuf, s, BUF_SIZE);
