(c)有名信号量在无相关进程间的同步
前面已经说过,有名信号量是位于共享内存区的,那么它要保护的资源也必须是位于
共享内存区,只有这样才能被无相关的进程所共享。
在下面这个例子中,服务进程和客户进程都使用shmget和shmat来获取得一块共享内
存资源。然后利用有名信号量来对这块共享内存资源进行互斥保护。
<u>File1: server.c </u>
#include <sys/types.h>
#include <sys/ipc.h>
#include <sys/shm.h>
#include <stdio.h>
#include <semaphore.h>
#include <sys/stat.h>
#include <fcntl.h>
#define SHMSZ 27
char SEM_NAME[]= "vik";
int main()
char ch;
int shmid;
key_t key;
char *shm,*s;
sem_t *mutex;
//name the shared memory segment
key = 1000;
//create & initialize semaphore
mutex = sem_open(SEM_NAME,O_CREAT,0644,1);
if(mutex == SEM_FAILED)
perror("unable to create semaphore");
sem_unlink(SEM_NAME);
exit(-1);
//create the shared memory segment with this key
shmid = shmget(key,SHMSZ,IPC_CREAT|0666);
if(shmid<0)
perror("failure in shmget");
exit(-1);
//attach this segment to virtual memory
shm = shmat(shmid,NULL,0);
//start writing into memory
s = shm;
for(ch='A';ch<='Z';ch++)
sem_wait(mutex);
*s++ = ch;
sem_post(mutex);
//the below loop could be replaced by binary semaphore
while(*shm != '*')
sleep(1);
sem_close(mutex);
shmctl(shmid, IPC_RMID, 0);
exit(0);
<u>File 2: client.c</u>
#include <stdio.h>
#include <fcntl.h>
#define SHMSZ 27
int main()
char ch;
int shmid;
key_t key;
char *shm,*s;
sem_t *mutex;
key = 1000;
//create & initialize existing semaphore
mutex = sem_open(SEM_NAME,0,0644,0);
perror("reader:unable to execute semaphore");
sem_close(mutex);
exit(-1);
shmid = shmget(key,SHMSZ,0666);
if(shmid<0)
perror("reader:failure in shmget");
exit(-1);
//start reading
s = shm;
for(s=shm;*s!=NULL;s++)
sem_wait(mutex);
putchar(*s);
sem_post(mutex);
//once done signal exiting of reader:This can be replaced by
another semaphore
*shm = '*';
sem_close(mutex);
exit(0);
六.SYSTEM V信号量
这是信号量值的集合,而不是单个信号量。相关的信号量操作函数由<sys/ipc.h>引用。
1.信号量结构体
内核为每个信号量集维护一个信号量结构体,可在<sys/sem.h>找到该定义:
struct semid_ds {
struct ipc_perm sem_perm; /* 信号量集的操作许可权限 */
struct sem *sem_base; /* 某个信号量sem结构数组的指针,当前信号量集
中的每个信号量对应其中一个数组元素 */
ushort sem_nsems; /* sem_base 数组的个数 */
time_t sem_otime; /* 最后一次成功修改信号量数组的时间 */
time_t sem_ctime; /* 成功创建时间 */
struct sem {
ushort semval; /* 信号量的当前值 */
short sempid; /* 最后一次返回该信号量的进程ID 号 */
ushort semncnt; /* 等待semval大于当前值的进程个数 */
ushort semzcnt; /* 等待semval变成0的进程个数 */
2.常见的SYSTEM V信号量函数
(a)关键字和描述符
SYSTEM V信号量是SYSTEM V IPC(即SYSTEM V进程间通信)的组成部分,其他
的有SYSTEM V消息队列,SYSTEM V共享内存。而关键字和IPC描述符无疑是它们的共
同点,也使用它们,就不得不先对它们进行熟悉。这里只对SYSTEM V信号量进行讨论。
IPC描述符相当于引用ID号,要想使用SYSTEM V信号量(或MSG、SHM),就必须
用IPC描述符来调用信号量。而IPC描述符是内核动态提供的(通过semget来获取),用
户无法让服务器和客户事先认可共同使用哪个描述符,所以有时候就需要到关键字KEY来
定位描述符。
某个KEY只会固定对应一个描述符(这项转换工作由内核完成),这样假如服务器和
客户事先认可共同使用某个KEY,那么大家就都能定位到同一个描述符,也就能定位到同
一个信号量,这样就达到了SYSTEM V信号量在进程间共享的目的。 |
