五:字符设备驱动程序分析:
(1)memdev.h
View Code
(2)memdev.c
复制代码
static mem_major = MEMDEV_MAJOR;
module_param(mem_major, int, S_IRUGO);
struct mem_dev *mem_devp; /*设备结构体指针*/
struct cdev cdev;
/*文件打开函数*/
int mem_open(struct inode *inode, struct file *filp)
struct mem_dev *dev;
/*获取次设备号*/
int num = MINOR(inode->i_rdev);
if (num >= MEMDEV_NR_DEVS)
return -ENODEV;
dev = &mem_devp[num];
/*将设备描述结构指针赋值给文件私有数据指针*/
filp->private_data = dev;
return 0;
/*文件释放函数*/
int mem_release(struct inode *inode, struct file *filp)
return 0;
/*读函数*/
static ssize_t mem_read(struct file *filp, char __user *buf, size_t size, loff_t *ppos)
unsigned long p = *ppos; /*记录文件指针偏移位置*/
unsigned int count = size; /*记录需要读取的字节数*/
int ret = 0; /*返回值*/
struct mem_dev *dev = filp->private_data; /*获得设备结构体指针*/
/*判断读位置是否有效*/
if (p >= MEMDEV_SIZE) /*要读取的偏移大于设备的内存空间*/
return 0;
if (count > MEMDEV_SIZE - p) /*要读取的字节大于设备的内存空间*/
count = MEMDEV_SIZE - p;
/*读数据到用户空间:内核空间->用户空间交换数据*/
if (copy_to_user(buf, (void*)(dev->data + p), count))
ret = - EFAULT;
else
*ppos += count;
ret = count;
printk(KERN_INFO "read %d bytes(s) from %d\n", count, p);
return ret;
/*写函数*/
static ssize_t mem_write(struct file *filp, const char __user *buf, size_t size, loff_t *ppos)
int ret = 0;
/*分析和获取有效的写长度*/
return 0;
if (count > MEMDEV_SIZE - p) /*要写入的字节大于设备的内存空间*/
/*从用户空间写入数据*/
if (copy_from_user(dev->data + p, buf, count))
ret = - EFAULT;
else
*ppos += count; /*增加偏移位置*/
ret = count; /*返回实际的写入字节数*/
printk(KERN_INFO "written %d bytes(s) from %d\n", count, p);
return ret;
/* seek文件定位函数 */
static loff_t mem_llseek(struct file *filp, loff_t offset, int whence)
loff_t newpos;
switch(whence) {
case 0: /* SEEK_SET */ /*相对文件开始位置偏移*/
newpos = offset; /*更新文件指针位置*/
break;
case 1: /* SEEK_CUR */
newpos = filp->f_pos + offset;
break;
case 2: /* SEEK_END */
newpos = MEMDEV_SIZE -1 + offset;
break;
default: /* can't happen */
return -EINVAL;
if ((newpos<0) || (newpos>MEMDEV_SIZE))
return -EINVAL;
filp->f_pos = newpos;
return newpos;
/*文件操作结构体*/
static const struct file_operations mem_fops =
.owner = THIS_MODULE,
.llseek = mem_llseek,
.read = mem_read,
.write = mem_write,
.open = mem_open,
.release = mem_release,
/*设备驱动模块加载函数*/
static int memdev_init(void)
int result;
int i;
dev_t devno = MKDEV(mem_major, 0);
/* 申请设备号,当xxx_major不为0时,表示静态指定;当为0时,表示动态申请*/
/* 静态申请设备号*/
if (mem_major)
result = register_chrdev_region(devno, 2, "memdev");
else /* 动态分配设备号 */
result = alloc_chrdev_region(&devno, 0, 2, "memdev");
mem_major = MAJOR(devno); /*获得申请的主设备号*/
if (result < 0)
return result;
/*初始化cdev结构,并传递file_operations结构指针*/
cdev_init(&cdev, &mem_fops);
cdev.owner = THIS_MODULE; /*指定所属模块*/
cdev.ops = &mem_fops;
/* 注册字符设备 */
cdev_add(&cdev, MKDEV(mem_major, 0), MEMDEV_NR_DEVS);
/* 为设备描述结构分配内存*/
mem_devp = kmalloc(MEMDEV_NR_DEVS * sizeof(struct mem_dev), GFP_KERNEL);
if (!mem_devp) /*申请失败*/
result = - ENOMEM;
goto fail_malloc;
memset(mem_devp, 0, sizeof(struct mem_dev));
/*为设备分配内存*/
for (i=0; i < MEMDEV_NR_DEVS; i++)
mem_devp[i].size = MEMDEV_SIZE;
mem_devp[i].data = kmalloc(MEMDEV_SIZE, GFP_KERNEL);
memset(mem_devp[i].data, 0, MEMDEV_SIZE);
return 0;
fail_malloc:
unregister_chrdev_region(devno, 1);
return result;
/*模块卸载函数*/
static void memdev_exit(void)
cdev_del(&cdev); /*注销设备*/
kfree(mem_devp); /*释放设备结构体内存*/
unregister_chrdev_region(MKDEV(mem_major, 0), 2); /*释放设备号*/
MODULE_AUTHOR("David Xie");
MODULE_LICENSE("GPL");
module_init(memdev_init);
module_exit(memdev_exit); |
