#include <stdio.h>
#include <signal.h>
#include <stdlib.h>
#include <unistd.h>
#include <string.h>
#include <linux/fb.h>
#include <fcntl.h>
#include <sys/types.h>
#include <sys/mman.h>
#include <sys/ioctl.h>
enum color{red, green, blue};
unsigned long *create_pixel(struct fb_var_screeninfo *pinfo,
enum color c)
unsigned long *pixel = calloc(1, pinfo->bits_per_pixel/8);
unsigned long *mask = calloc(1, pinfo->bits_per_pixel/8);
*mask |= 0x1;
int i;
switch(c)
case red:
for(i=0; i<pinfo->red.length-1; i++)
*mask <<= 1;
*mask |= 0x1;
*pixel |= *mask << pinfo->red.offset;
break;
case green:
for(i=0; i<pinfo->green.length-1; i++)
*mask <<= 1;
*mask |= 0x1;
*pixel |= *mask << pinfo->green.offset;
break;
case blue:
for(i=0; i<pinfo->blue.length-1; i++)
*mask <<= 1;
*mask |= 0x1;
*pixel |= *mask << pinfo->blue.offset;
return pixel;
int main(void)
// fb = frame buffer
int lcd = open("/dev/fb0", O_RDWR);
if(lcd == -1)
perror("open(\"/dev/fb0\")");
exit(1);
struct fb_fix_screeninfo finfo;
struct fb_var_screeninfo vinfo;
ioctl(lcd, FBIOGET_FSCREENINFO, &finfo);
ioctl(lcd, FBIOGET_VSCREENINFO, &vinfo);
vinfo.xoffset = 0;
vinfo.yoffset = 0;
ioctl(lcd, FBIOPAN_DISPLAY, &vinfo);
unsigned long bpp = vinfo.bits_per_pixel;
unsigned long *pixel[3] = {0};
pixel[0] = create_pixel(&vinfo, red);
pixel[1] = create_pixel(&vinfo, green);
pixel[2] = create_pixel(&vinfo, blue);
char *FB = mmap(NULL, vinfo.xres * vinfo.yres * bpp/8,
PROT_READ | PROT_WRITE, MAP_SHARED,
lcd, 0);
int k;
for(k=0; ;k++)
int i;
for(i=0; i<vinfo.xres * vinfo.yres; i++)
memcpy(FB+i*bpp/8, pixel[k%3], bpp/8);
sleep(1);
return 0;
