module MYFX2 ( nRESET,// Inputs from FX2 PA, KEY, MMCLK, //from cytal LED, // LED indicator GPD, CTL,RDY ); ////////////////////////////////// inout [15:0]GPD; input [2:0]CTL; output [1:0]RDY; reg [1:0]RDY; //////////////////////////////////////////// input nRESET; /////////////////////////////////// input [3:0]KEY; inout [7:0]PA; ////////////////////////////////// input MMCLK; output [3:0]LED; reg [3:0]LED; reg [15:0]DREG; reg BLable; //output USBCLK; reg [1:0] STATE,NEXT;
reg CLK_2,CLK_4,CLK_8; wire HCLK; parameter IDLE = 2'D0, WRITE_1 = 2'D1, WRITE_2 = 2'D2; assign PA[4]=0; assign PA[5]=1; assign GPD[15:0]=RDY[1]? 'hz REG[15:0];
always @(posedge MMCLK) begin CLK_2 <= ~CLK_2; end always @(posedge CLK_2) begin CLK_4 <= ~CLK_4; end always @(posedge CLK_4) begin CLK_8 <= ~CLK_8; end
assign HCLK = CLK_8; //state machine always @ (STATE or LED[0]) begin case(STATE) IDLE : if(LED[0]) NEXT = WRITE_1; else NEXT = IDLE ; WRITE_1 : NEXT = WRITE_2; WRITE_2 : NEXT = WRITE_1; default : NEXT = IDLE ; endcase end //registe the state always @(posedge HCLK or negedge nRESET) if(!nRESET) begin STATE <= IDLE; end else STATE <= NEXT; always @(posedge HCLK or negedge nRESET) if(!nRESET) begin DREG <=16'hffff; RDY[1] <=1'b1; RDY[0] <=1'b1; LED[0] <= 1'b1; // BLable=1; end else case(STATE) IDLE : begin RDY[0] <= 1; RDY[1] <= 1; end WRITE_1 : begin // if (BLable==1) // begin DREG <= DREG+1; // if (DREG==255) BLable=0; // end // if (BLable==0) // begin // DREG <= DREG-1; // if (DREG==0) BLable=1; // end RDY[1] <= 1'b0; RDY[0] <= 1'b1; end WRITE_2 : begin RDY[1] <= 1'b1; RDY[0] <= 1'b1; end endcase |
