高手进,急急急!
高手进,急急急!
注:此程序是在[url=profile-uid-92212.html]zkf0100007[/url]的亲自帮助下完成的,,受益菲浅,在此深为感谢:
PS:Xilinx Spartan 3E Starter Kit平台上LCD1602与板载Intel Flash Memory公用四根数据线,读写命令和数据时分别写高四位和低四位,具体请查阅三楼的数据手册
源码:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity LCD1602 is
  ort (
               CLK : in std_logic;
             Reset : in std_logic;
          LCD_RS : out std_logic;
         LCD_RW : out std_logic;
          LCD_EN : out std_logic;
               data : out std_logic_vector(3 downto 0));
end LCD1602;
architecture Behavioral of LCD1602 is
  type iState is (
                          Write_instr,      --写命令字
                 Write_DataUP4_1,      --写LCD一线高4位
             Write_DataDown4_1,      --写LCD一线低4位
               Set_DDRamAddUp,      --设置DDRam地址高4位
           Set_DDRamAddDown,      --设置DDRam地址低4位
                Write_DataUP4_2,       --写LCD二线高4位
             Write_DataDown4_2       --写LCD二线低4位
  signal State:iState;
  type Ram is array(0 to 15) of std_logic_vector(7 downto 0);
  constant   MyRamUp:Ram:=(x"46",x"68",x"69",x"73",x"20",x"49",x"73",x"20",x"4d",x"79",x"20",x"46",x"69",x"72",x"73",x"74");
                           --This  Is My First
  constant MyRamDown:Ram:=(x"20",x"20",x"46",x"50",x"47",x"41",x"20",x"50",x"72",x"6f",x"67",x"72",x"61",x"6d",x"20",x"20");
                           --FPGA Program
  signal  LCD_Clk : std_logic :='0';
  signal  datacnt : integer range 0 to 15:=0;
begin
  LCD_RW <= '0';
  LCD_EN <= LCD_Clk;
process(CLK)                                         --20000分频,满足时序要求
  variable n1:integer range 0 to 19999;
begin
  if rising_edge(CLK) then
    if n1<19999 then
       n1:=n1+1;
    else
       n1:=0;
       LCD_Clk<=not LCD_Clk;
    end if;
  end if;
end process;
process(LCD_Clk,state,reset)
begin
  if Reset='0' then
      state<=Write_instr;
      LCD_RS <= '0';
  elsif rising_edge(LCD_Clk) then
      case state is
   when Write_instr=>              --写命令字到LCD控制器
      LCD_RS<='0';
      if(datacnt=0)then
        data<="0011";                --0011
        datacnt<=datacnt+1;
      elsif(datacnt=1)then
        datacnt<=datacnt+1;
      elsif(datacnt=2)then
        datacnt<=datacnt+1;
      elsif(datacnt=3)then
        data<="0010";                --0010
        datacnt<=datacnt+1;
      elsif(datacnt=4)then           --0x28  :   0010 1000 =>功能设置
        data<="0010";
        datacnt<=datacnt+1;
      elsif(datacnt=5)then
        data<="1000";
        datacnt<=datacnt+1;
      elsif(datacnt=6)then           --0x06  :   0000 0110 =>模式设定
        data<="0000";
        datacnt<=datacnt+1;
      elsif(datacnt=7)then
        data<="0110";
        datacnt<=datacnt+1;
      elsif(datacnt=8)then          --0x0c  :    0000 1100 =>显示设定
        data<="0000";
        datacnt<=datacnt+1;
      elsif(datacnt=9)then
        data<="1100";
        datacnt<=datacnt+1;
      elsif(datacnt=10)then       --0x10  : 1000 0000 =>00H 设定读写地址位
        data<="1000";
        datacnt<=datacnt+1;
      else
        data<="0000";
        datacnt<=0;
      state<=Write_DataUP4_1;
      end if;
   when Write_DataUP4_1=>
      LCD_RS<='1';
      data <= MyRamUp(datacnt)(7 downto 4);
      state <= Write_DataDown4_1;
   when Write_DataDown4_1=>
      if datacnt=15 then
        data <= MyRamUp(datacnt)(3 downto 0);
        datacnt<=0;
        state <=Set_DDRamAddUp;
      else
        datacnt<=datacnt+1;
        state <=Write_DataUP4_1;
      end if;
   when Set_DDRamAddUp=> --0xc0  :  1100 0000=>40H  设定读写地址位
        LCD_RS<='0';
        data<="1100";
        state<=Set_DDRamAddDown;
   when Set_DDRamAddDown=>
        data<="0000";
        state<=Write_DataUP4_2;
   when Write_DataUP4_2=>
        LCD_RS<='1';
        data <= MyRamDown(datacnt)(7 downto 4);
        state <= Write_DataDown4_2;
   when Write_DataDown4_2=>
        if datacnt=15 then
          data <= MyRamDown(datacnt)(3 downto 0);
          datacnt<=0;
        else
          datacnt<=datacnt+1;
          state <=Write_DataUP4_2;
        end if;
   when others=>
        state<=Write_instr;
   end case;
   end if;
end process;
end Behavioral;
这个程序运行后,怎么显示器上什么都没有啊?怎么回事?应该怎样才能显示字母?
