关于FPGA的问题1
关于FPGA的问题1
各位高手,小弟正在向NIOS上移植FATFS文件系统。移植完成后,调用f_open创建并打开一个文件,这个时候遇到“打开失败”。调试了一下,发现check_fs函数中的LD_WORD
(&fs->win[BS_55AA])!=0xAA55判断失败,返回2。请教其中的原因。谢谢!部分代码如下:
static
BYTE check_fs (   /* 0:FATboor sector, 1:Valid boor sector but not FAT, 2:Not a boot sector, 3isk error*/
    FATFS* fs, /* File system object */
    DWORD sect /* Sector# (lba) to check if it is an FAT boot record ornot */
    WORD temp;
    fs->wflag = 0; fs->winsect = 0xFFFFFFFF;  /* Invaidatewindow */
    if (move_window(fs, sect) != FR_OK)           /* Load bootrecord */
       return 3;
    if (LD_WORD(&fs->win[BS_55AA]) != 0xAA55) /* Check bootrecord signature (always placed at offset 510 even if the sector size is>512) */
        return 2;
    if ((LD_DWORD(&fs->win[BS_FilSysType])& 0xFFFFFF) == 0x544146)    /* Check "FAT" string */
       return 0;
    if ((LD_DWORD(&fs->win[BS_FilSysType32]) &0xFFFFFF) == 0x544146)  /* Check "FAT" string */
       return 0;
    return 1;
