[求助]用与门实现毛刺检测,大家看看我的程序有什么问题?在线等!
- 女
library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; ---- Uncomment the following library declaration if instantiating ---- any Xilinx primitives in this code. --library UNISIM; --use UNISIM.VComponents.all; --synopsys translate_on entity mcjc is Port ( a_in : in STD_LOGIC; q_out : out STD_LOGIC); end mcjc; architecture Behavioral of mcjc is signal b,c,d,e:STD_LOGIC; begin process(a_in) begin b<=a_in; c<=b; d<=c; e<=d; q_out<=a_in and b and c and d and e; end process; end Behavioral; 我的程序编译没什么问题,可是仿真出来,没有输出,不知道是怎么回事,大家帮忙看一下哪出了问题?谢谢1
