双链表其实 也没什么 只是多了一个前置链而已
双链表的定义
复制代码 代码如下:
struct DNode
int data;
struct DNode *next;
struct DNode *pre;
单链表的定义
复制代码 代码如下:
view plaincopy
struct DNode
int data;
struct DNode *next;
其他的可以看上一篇博客 大致相同
复制代码 代码如下:
#ifndef HEAD_H
#define HEAD_H
#include <iostream>
using namespace std;
#include <cassert>
#include <cstdlib>
#include <cmath>
#include <sstream>
#include <fstream>
#include <string>
#include <algorithm>
#include <list>
#include <queue>
#include <vector>
#include <deque>
#include <stack>
#include <bitset>
#include <set>
#include <map>
#endif
struct DNode
int data;
struct DNode *next;
struct DNode *pre;
DNode *Creat()
DNode *head,*p,*s;
head=(DNode *)malloc(sizeof(DNode));
p=head;
int temp;
while (cin>>temp&&temp)
s=(DNode *)malloc(sizeof(DNode));
s->data=temp;
p->next=s;
s->pre=p;
p=s;
head=head->next;
p->next=NULL;
head->pre=NULL;
return (head);
DNode *Insert(DNode *&head,int num)
DNode *p,*s;
s->data=num;
p=head;
while (NULL!=p->next&&num>p->data)
p=p->next;
if (num<=p->data)
if (NULL==p->pre)
s->next=head;
head->pre=s;
head=s;
head->pre=NULL;
else
s->pre=p->pre;
p->pre->next=s;
s->next=p;
p->pre=s;
else
p->next=s;
s->pre=p;
s->next=NULL;
return(head);
DNode *Del(DNode *&head,int num)
DNode *p;
p=head;
while (NULL!=p->next&&num!=p->data)
p=p->next;
if (num==p->data)
if (NULL==p->pre)
head=p->next;
p->next->pre=head;
free(p);
else if (NULL==p->next)
p->pre->next=NULL;
free(p);
else
p->pre->next=p->next;
p->next->pre=p->pre;
free(p);
else
cout<<num<<" cound not be found"<<endl;
return head;
void Display(DNode *head)
DNode *p;
p=head;
while (NULL!=p)
cout<<(p->data)<<" ";
p=p->next;
cout<<endl;
复制代码 代码如下:
#include "head.h"
int main()
DNode *head;
head=Creat();
Display(head);
#ifndef DEBUG
cout<<"please input an num to insert:";
#endif
int insert_num;
while (cin>>insert_num&&insert_num)
Insert(head,insert_num);
Display(head);
#ifndef DEBUG
cout<<"please input an number to delete:";
#endif
int delete_num;
while (cin>>delete_num&&delete_num)
Del(head,delete_num);
Display(head);
return (EXIT_SUCCESS);
