C++开发在IOS环境下运行的LRUCache缓存功能(2)
这里并未使用pthread_mutex_t来设计锁,而是使用了__sync_fetch_and_add指令体系,当然最终是否如上面链接中作者所说的比pthread_mutex_t性能要高7-8倍,我没测试过,感兴趣的朋友也可以帮助测试一下。
有了这两个类之后,我又补充了原文作者中所提到了KEY比较方法的定义,同时引入了id来支持object-c的对象缓存,最终代码修改如下:
[url=]复制代码[/url] 代码如下:
#ifndef _MAP_LRU_CACHE_H_
#define _MAP_LRU_CACHE_H_
#include <string.h>
#include <iostream>
#include "rwlock.h"
#include <stdio.h>
#include <sys/malloc.h>
using namespace std;
namespace lru_cache {
static const int DEF_CAPACITY = 100000;//默认缓存记录数
typedef unsigned long long virtual_time;
typedef struct _HashKey
NSString* key;
}HashKey;
typedef struct _HashValue
id value_;
virtual_time access_;
}HashValue;
//仅针对HashKey比较器
template <class key_t>
struct hashkey_compare{
bool operator()(key_t x, key_t y) const{
return x < y;
template <>
struct hashkey_compare<HashKey>
bool operator()(HashKey __x, HashKey __y) const{
string x = [__x.key UTF8String];
string y = [__y.key UTF8String];
return x < y;
//自定义map类型
template <typename K, typename V, typename _Compare = hashkey_compare<K>,
typename _Alloc = std::allocator<std::pair<const K, V> > >
class lru_map: public map<K, V, _Compare, _Alloc>{};
class CLRUCache
public:
CLRUCache() : _now(0){
_lru_list = shared_ptr<lru_map<virtual_time, HashKey> >(new lru_map<virtual_time, HashKey>);
_hash_table = shared_ptr<lru_map<HashKey, HashValue> > (new lru_map<HashKey, HashValue>);
~CLRUCache(){
_lru_list->clear();
_hash_table->clear();
int set( const HashKey& key, const id &value )
HashValue hash_value;
hash_value.value_ = value;
hash_value.access_ = get_virtual_time();
pair< map<HashKey, HashValue>::iterator, bool > ret = _hash_table->insert(make_pair(key, hash_value));
if ( !ret.second ){
// key already exist
virtual_time old_access = (*_hash_table)[key].access_;
map<virtual_time, HashKey>::iterator iter = _lru_list->find(old_access);
if(iter != _lru_list->end())
_lru_list->erase(iter);
_lru_list->insert(make_pair(hash_value.access_, key));
(*_hash_table)[key] = hash_value;
else {
if ( _hash_table->size() > DEF_CAPACITY )
// get the least recently used key
map<virtual_time, HashKey>::iterator iter = _lru_list->begin();
_hash_table->erase( iter->second );
// remove last key from list
return 0;
HashValue* get( const HashKey& key )
map<HashKey, HashValue>::iterator iter = _hash_table->find(key);
if ( iter != _hash_table->end() )
virtual_time old_access = iter->second.access_;
iter->second.access_ = get_virtual_time();
//调整当前key在LRU列表中的位置
map<virtual_time, HashKey>::iterator it = _lru_list->find(old_access);
if(it != _lru_list->end()) {
_lru_list->erase(it);
_lru_list->insert(make_pair(iter->second.access_, key));
return &(iter->second);
else{
return NULL;
unsigned get_lru_list_size(){ return (unsigned)_lru_list->size(); }
unsigned get_hash_table_size() { return (unsigned)_hash_table->size(); }
virtual_time get_now() { return _now; }
private:
virtual_time get_virtual_time()
return ++_now;
shared_ptr<lru_map<virtual_time, HashKey> > _lru_list;
shared_ptr<lru_map<HashKey, HashValue> > _hash_table;
virtual_time _now;
#endif
接下来看一下如果结合单例和rwlock来设计最终的缓存功能,如下:
using namespace lru_cache;
class DZCache: public Singlton<DZCache>
friend class Singlton<DZCache>;
private:
shared_ptr<CLRUCache> clu_cache;
rwlock *lock;
DZCache(){
lock =(rwlock*) malloc(sizeof(rwlock));
rwlock_init(lock);
clu_cache = shared_ptr<CLRUCache>(new CLRUCache());
cout << "construct JobList" << endl;
DZCache * Instance() {
return s_instance.get();
public:
~DZCache(){
free(lock);
static DZCache& getInstance(){
return *instance();
void set(NSString* key, id value){
//加锁
rwlock_wlock(lock);
HashKey hash_key;
hash_key.key = key;
clu_cache->set(hash_key, value);
rwlock_wunlock(lock);
id get(NSString* key){
HashKey hash_key;
hash_key.key = key;
HashValue* value = clu_cache->get(hash_key);
if(value == NULL){
return nil;
else{
return value->value_;
#endif
最后看一下如何使用:
void testLRUCache(){
//指针方式
DZCache::instance()->set(@"name", @"daizhj");//设置
NSString* name = (NSString*)DZCache::instance()->get(@"name");//获取
std::cout<<[name UTF8String]<<endl;
NSNumber * age=[NSNumber numberWithInt:123123];
DZCache::instance()->set(@"age", age);
age = (NSNumber*)DZCache::instance()->get(@"age");
//对象方式
DZCache::getInstance().set(@"name", @"daizhenjun");
name = (NSString*)DZCache::getInstance().get(@"name");
age = [NSNumber numberWithInt:123456];
DZCache::getInstance().set(@"age", age);
age = (NSNumber*)DZCache::getInstance().get(@"age");
