谈谈23种设计模式在Android项目中的应用(2)
工厂模式
简单工厂模式
定义
建立一个工厂(一个函数或一个类方法)来制造新的对象。
示例
public static Operation createOperate(string operate) {
Operation oper = null;
switch (operate)
case "+":
oper = new OperationAdd();
break;
case "-":
oper = new OperationSub();
break;
case "*":
oper = new OperationMul();
break;
case "/":
oper = new OperationDiv();
break;
return oper;
Android
public Object getSystemService(String name) {
if (getBaseContext() == null) {
throw new IllegalStateException("System services not available to Activities before onCreate()");
if (WINDOW_SERVICE.equals(name)) {
return mWindowManager;
} else if (SEARCH_SERVICE.equals(name)) {
ensureSearchManager();
return mSearchManager;
return super.getSystemService(name);
在getSystemService方法中就是用到了简单工厂模式,根据传入的参数决定创建哪个对象,由于这些对象以单例模式提前创建好了,所以此处不用new了,直接把单例返回就好。
重构
//重构前
public class AdvertPresenter {
private void initAdvertManager() {
String[] platforms = mAdConfig.getAllPlatforms();
if (platforms != null && platforms.length > 0) {
int platformSize = platforms.length;
for (int i = 0; i < platformSize; i++) {
String platform = platforms[i];
if (platform.equalsIgnoreCase(AdvertConstant.AD_PLATFORM_FACEBOOK)) {
FacebookAdvertManager fbAdManager = new FacebookAdvertManager();
mAdvertManager.put(AdvertConstant.AD_PLATFORM_FACEBOOK, fbAdManager);
} else if (platform.equalsIgnoreCase(AdvertConstant.AD_PLATFORM_ADMOB)) {
AdMobAdvertManager adMobAdvertManager = new AdMobAdvertManager();
mAdvertManager.put(AdvertConstant.AD_PLATFORM_ADMOB, adMobAdvertManager);
} else if (platform.equalsIgnoreCase(AdvertConstant.AD_PLATFORM_MOPUB)) {
MopubAdvertManager mopubAdvertManager = new MopubAdvertManager();
mAdvertManager.put(AdvertConstant.AD_PLATFORM_MOPUB, mopubAdvertManager);
} else if (platform.equalsIgnoreCase(AdvertConstant.AD_PLATFORM_ADX)) {
AdxAdvertManager mopubAdvertManager = new AdxAdvertManager();
mAdvertManager.put(AdvertConstant.AD_PLATFORM_ADX, mopubAdvertManager);
//重构后
public class BaseAdvertManager {
public static BaseAdvertManager create(String platform) {
return new FacebookAdvertManager();
return new MopubAdvertManager();
return new AdxAdvertManager();
return new AdMobAdvertManager();
} else {
***return new NullAdvertManager();***//引入NULL对象
mAdvertManager.put(platform, BaseAdvertManager.create(platform));
工厂方法模式
定义
是定义一个创建产品对象的工厂接口,让其子类决定实例化哪一个类,将实际创建工作推迟到子类当中。
示例
public abstract class Product {
public abstract void method();
public class ConcreteProduct extends Prodect {
public void method(){
System.out.println("我是具体产品!");
public abstract class Factory{
public abstract Product createProduct();
public class ConcreteFactory extends Factory{
public Product createProduct(){
return new ConcreteProductA();
Android
我们在开发中会用到很多数据结构,比如ArrayList,HashMap等。我们先来看下Java中Collection部分的类集框架的简要UML图。
我们知道Iterator是迭代器,用来遍历一个集合中的元素。而不同的数据结构遍历的方式是不一样的,所以迭代器的实现也是不同的。使用工厂方法模式将迭代器的具体类型延迟到具体容器类中,比较灵活,容易扩展。
public interface Iterable {
/** * Returns an iterator over elements of type {@code T}. * * @return an Iterator. */
Iterator iterator();
//省略部分代码
List和Set继承自Collection接口,Collection接口继承于Iterable接口。所以List和Set接口也需要继承并实现Iterable中的iterator()方法。然后我们常用的两个间接实现类ArrayList和HashSet中的iterator方法就给我们具体构造并返回了一个迭代器对象。
我们找到ArrayList类,查看iterator方法的实现。
@Override
public Iterator iterator() {
return new ArrayListIterator();
