基于稀疏图上的Johnson算法的详解(2)
int min_heapify(struct vassist *va, int i,int heap_size) {
    int l,r,min;
    struct vassist temp;
    int tmin = U;
    l = LEFT(i);
    r = RIGHT(i);
    if ((l < heap_size) &&(va[l].d<va[i].d)) {
        min = l;
        tmin = va[l].d;
    else {
        min = i;
        tmin = va[i].d;
    if ((r < heap_size) &&(va[r].d<va[min].d)) {
        min = r;
        tmin = va[r].d;
    if (!(min == i)) {
        temp.d = va[min].d;
        temp.p = va[min].p;
        temp.key = va[min].key;
        va[min].d = va[i].d;
        va[min].p = va[i].p;
        va[min].key = va[i].key;
        va[i].d = temp.d;
        va[i].p = temp.p;
        va[i].key = temp.key;
        min_heapify(va,min,heap_size);
    return 1;
int heap_extract_min(struct vassist *va,int heap_size) {
    int min;
    if ( heap_size<1 )
        return -1;
    min = va[0].key;
    va[0].p = va[heap_size -1].p;
    va[0].d = va[heap_size -1].d;
    va[0].key = va[heap_size -1].key;
    heap_size = heap_size -1;
    min_heapify(va,0,heap_size);
    return min;
int inheap(struct vassist *va,int heap_size,int j) {
    int i;
    for(i=0;i<heap_size;i++)
        if(va[i].key == j)
            return i;
    return -1;
int heap_decrease(struct vassist *va,int i,int key_new) {
    if(key_new>va[i].d)
        return 0;
    va[i].d = key_new;
    while((i>0)&&(va[PARENT(i)].d > va[i].d)) {
        temp.d = va[i].d;
        temp.p = va[i].p;
        temp.key = va[i].key;
        va[i].d = va[PARENT(i)].d;
        va[i].p = va[PARENT(i)].p;
        va[i].key = va[PARENT(i)].key;
        va[PARENT(i)].d = temp.d;
        va[PARENT(i)].p = temp.p;
        va[PARENT(i)].key = temp.key;
        i = PARENT(i);
    return 1;
int dijkstra(struct vertex *graph,int len,int s,int **delta) {
    int i,j,heap_size;
    struct vtable *q;
    struct vassist *va;
    int *p;
    p = (int *)malloc(len * sizeof(int));
    for(i=0;i<len;i++)
        p[i] = U;
    p[s] = 0;
    heap_size = len;
    va = initialize_ss(len,s);
    build_min_heap(va,heap_size);//va被拿去建堆,后续输出距离时不能再用了
    while(heap_size>0) {
        i = heap_extract_min(va,heap_size);
        printf("node:%d\n",i);
        heap_size--;
        for(j=0;j<heap_size;j++)
            printf("key:%d,d:%d, in array:%d\n",va[j].key,va[j].d,p[va[j].key]);
        q = graph[i].adj;
        while(q!=NULL) {
            j=inheap(va,heap_size,q->key);
            if(j>=0)
                if(va[j].d>p[i]+q->w)
                    heap_decrease(va,j,p[i]+q->w);
            relaxd(p,i,q->key,q->w);//其实可以合并heap_decreas和relax,不过为了接口简单没有这样做
            printf("relax %d to %d ,w is %d\n",i,q->key,q->w);
            q = q->next;
    for(i=0;i<len;i++)
        printf("from %d to %d, distance is %d\n",s,i,p[i]);
    free(va);
    for(i=0;i<len;i++) {
        delta[s][i] = p[i];
    free(p);
int **johnson(struct vertex *g, int n) {
    int i,j;
    int *h,**delta,**d;
    struct vertex *gn;
    struct vtable *p;
    gn = (struct vertex *)malloc(n*sizeof(struct vertex));
    h = (int *)malloc(n*sizeof(int));
    delta = (int**)malloc(n*sizeof(int *));
    d = (int**)malloc(n*sizeof(int *));
    for(i=0;i<n;i++) {
        delta[i]=(int*)malloc(n*sizeof(int));
        d[i]=(int*)malloc(n*sizeof(int));
    for(i=0;i<n;i++)
        gn[i] = g[i];
    for(i=1;i<n;i++)
            insert(gn,n,0,i,0);
    if(!bellman_ford(gn,h,n,0)) {
        printf("the input graph contains a negative-weight cycle.\n");
        return NULL;
    for(i=0;i<n;i++) {
        p = gn[i].adj;
        while(p!=NULL) {
            p->w = p->w+h[i]-h[p->key];
            p=p->next;
    for(i=0;i<n;i++)
        walk(gn,n,i);
    printf("before dijkstra\n");
    for(i=1;i<n;i++) {
        dijkstra(gn,n,i,delta);
        for(j=1;j<n;j++)
            d[i][j] = delta[i][j] + h[j] - h[i];
    for(i=1;i<n;i++) {
        for(j=1;j<n;j++)
            printf("%d\t",d[i][j]);
        printf("\n");
    return d;
int main(){
    int i,j;
    int **d;
    struct vertex vt[N+1];//为0结点的加入预留位置
    for(i=0;i<N+1;i++) {
        vt[i].adj = NULL;
        vt[i].key = i;
    insert(vt,N+1,1,2,3);
    insert(vt,N+1,1,3,8);
    insert(vt,N+1,1,5,-4);
    insert(vt,N+1,2,4,1);
    insert(vt,N+1,2,5,7);
    insert(vt,N+1,3,2,4);
    insert(vt,N+1,4,3,-5);
    insert(vt,N+1,4,1,2);
    insert(vt,N+1,5,4,6);
    d = johnson(vt,N+1);
    return 1;
继承事业,薪火相传
