Linux中编译安装Subversion(SVN)客户端的教程(2)
3. 安装svn
复制代码
代码如下:
tar xzf subversion-1.8.1.tar.gz
cd subversion-1.8.1
./get-deps.sh
./configure --prefix=/usr/local/subversion --with-apxs=/usr/local/apache/bin/apxs \
--with-apr=/usr/local/apache --with-apr-util=/usr/local/apache --with-zlib \
--with-openssl --enable-maintainer-mode --with-serf=/usr/local/serf --enable-mod-activation
make && make install
cd ..
4. 检查是否安装成功
安装成功会在/usr/local/apache/conf/httpd.conf自己加入下面2行
复制代码
代码如下:
LoadModule dav_svn_module /usr/local/subversion/libexec/mod_dav_svn.so
LoadModule authz_svn_module /usr/local/subversion/libexec/mod_authz_svn.so
检查svn是否支持http方式:
复制代码
代码如下:
# svn --version
svn, version 1.8.1 (r1503906)
compiled Aug 2 2013, 11:36:48 on x86_64-unknown-linux-gnu
Copyright (C) 2013 The Apache Software Foundation.
This software consists of contributions made by many people;
see the NOTICE file for more information.
Subversion is open source software, see http://subversion.apache.org/
The following repository access (RA) modules are available:
* ra_svn : Module for accessing a repository using the svn network protocol.
- with Cyrus SASL authentication
- handles 'svn' scheme
* ra_local : Module for accessing a repository on local disk.
- handles 'file' scheme
* ra_serf : Module for accessing a repository via WebDAV protocol using serf.
- handles 'http' scheme
- handles 'https' scheme |
