内核调试的方法(2)
内核调试的方法(2)
//9,栈信息
Stack: (0xc3c7be88 to 0xc3c7c000)
be80:                   c3c7bebc c3c7be98 c008d888 bf000010 00000000 c049abc0
bea0: c3e740c0 c008d73c c0474e20 c3e766a8 c3c7bee4 c3c7bec0 c0089e48 c008d74c
bec0: c049abc0 c3c7bf04 00000003 ffffff9c c002c044 c3d10000 c3c7befc c3c7bee8
bee0: c0089f64 c0089d58 00000000 00000002 c3c7bf68 c3c7bf00 c0089fb8 c0089f40
bf00: c3c7bf04 c3e766a8 c0474e20 00000000 00000000 c3eb1000 00000101 00000001
bf20: 00000000 c3c7a000 c04a7468 c04a7460 ffffffe8 c3d10000 c3c7bf68 c3c7bf48
bf40: c008a16c c009fc70 00000003 00000000 c049abc0 00000002 bec1fee0 c3c7bf94
bf60: c3c7bf6c c008a2f4 c0089f88 00008520 bec1fed4 0000860c 00008670 00000005
bf80: c002c044 4013365c c3c7bfa4 c3c7bf98 c008a3a8 c008a2b0 00000000 c3c7bfa8
bfa0: c002bea0 c008a394 bec1fed4 0000860c 00008720 00000002 bec1fee0 00000001
bfc0: bec1fed4 0000860c 00008670 00000002 00008520 00000000 4013365c bec1fea8
bfe0: 00000000 bec1fe84 0000266c 400c98e0 60000010 00008720 00000000 00000000
//10,栈回溯信息,可以从中看出函数调用关系:从最后一个函数 sys_init_module 开始,向上可以找到函数调用的关系。
//可以通过内核配置信息 make menuconfig 来指定是否输出 栈回溯信息。
Backtrace: (回溯)
[] (first_drv_open+0x0/0x3c [first_drv]) from [] (chrdev_open+0x14c/0x164)
[] (chrdev_open+0x0/0x164) from [] (__dentry_open+0x100/0x1e8)
r8:c3e766a8 r7:c0474e20 r6:c008d73c r5:c3e740c0 r4:c049abc0
[] (__dentry_open+0x0/0x1e8) from [] (nameidata_to_filp+0x34/0x48)
[] (nameidata_to_filp+0x0/0x48) from [] (do_filp_open+0x40/0x48)
r4:00000002
[] (do_filp_open+0x0/0x48) from [] (do_sys_open+0x54/0xe4)
r5:bec1fee0 r4:00000002
[] (do_sys_open+0x0/0xe4) from [] (sys_open+0x24/0x28)
[] (sys_open+0x0/0x28) from [] (ret_fast_syscall+0x0/0x2c)
Code: e24cb004 e59f1024 e3a00000 e5912000 (e5923000)
Segmentation fault
b). 编入内核
Modules linked in:
CPU: 0    Not tainted  (2.6.22.6 #2)
PC is at first_drv_open+0x18/0x3c
LR is at chrdev_open+0x14c/0x164
pc : []    lr : []    psr: a0000013
sp : c3a03e88  ip : c3a03e98  fp : c3a03e94
r10: 00000000  r9 : c3a02000  r8 : c03f3c60
r7 : 00000000  r6 : 00000000  r5 : c38a0c50  r4 : c3c1e780
r3 : c014e6a8  r2 : 56000050  r1 : c031a47c  r0 : 00000000
Flags: NzCv  IRQs on  FIQs on  Mode SVC_32  Segment user
Control: c000717f  Table: 339f0000  DAC: 00000015
Process firstdrvtest (pid: 750, stack limit = 0xc3a02258)
1. 根据pc值确定该指令属于内核还是外加的模块
pc = c014e6c0 它属于什么的地址?是内核的地址,还是通过insmod加载的驱动程序的地址?
先判断是否属于内核的地址 : 看 内核编译makefile目录下的 System.map(编译完内核都会发现在内核根目录下面多出来一个System.map文件)
确定内核的函数的地址范围 : c0004000~c03faa94。
所以可以确定 : 导致错误的指令不在内核的地址范围,则它属于insmod加载的驱动程序的地址范围。
2. 反汇编内核: arm-linux-objdump -D vmlinux > vmlinux.dis
vmlinux是未压缩的内核,vmlinux 是ELF文件,即编译出来的最原始的文件。用于kernel-debug,产生system.map符号表,不能用于直接加载,不可以作为启动内核。只是启动过程中的中间媒体
vmlinuz是可引导的、压缩的内核。“vm”代表“Virtual Memory”。Linux 支持虚拟内存,不像老的操作系统比如DOS有640KB内存的限制
first_drv.dis文件中:搜c014e6c0
c014e6a8 :
c014e6a8:       e1a0c00d        mov     ip, sp
c014e6ac:       e92dd800        stmdb   sp!, {fp, ip, lr, pc}
c014e6b0:       e24cb004        sub     fp, ip, #4      ; 0x4
c014e6b4:       e59f1024        ldr     r1, [pc, #36]   ; c014e6e0 <.text+0x1276e0>
c014e6b8:       e3a00000        mov     r0, #0  ; 0x0
c014e6bc:       e5912000        ldr     r2, [r1]
c014e6c0:       e5923000        ldr     r3, [r2] // 在此出错 r2=56000050,在下面可以找到
c).根据栈信息分析函数调用过程(作为模块 或者 编入内核都可,下面的实验是作为模块)
# ./firstdrvtest on
Unable to handle kernel paging request at virtual address 56000050
pgd = c3e78000
[56000050] *pgd=00000000
Internal error: Oops: 5 [#1]
Modules linked in: first_drv
CPU: 0    Not tainted  (2.6.22.6 #48)
PC is at first_drv_open+0x18/0x3c [first_drv]
1 根据PC确定出错位置,是在内核,还是在模块中,前面有详细的分析System.map
bf000018 属于 insmod的模块
bf000000 t first_drv_open       [first_drv]
2 确定它属于哪个函数
有时候 Modules linked in: 会指明是哪个驱动程序,但是很多时候加载的驱动程序很多,是不会指明具体是哪个。
所以还是需要根据PC值来确定究竟是哪个驱动程序。
先看看加载的驱动程序的地址范围。
在开发板目录下 : cat /proc/kallsyms >> kallsyms.txt (内核函数的地址、加载的函数的地址)
kallsyms.txt文件中的内容介绍 //T : 表示全局函数 t : 表示静态函数
3 找到了first_drv.ko
在PC上反汇编它: arm-linux-objdump -D first_drv.ko > first_drv.dis
在dis文件里找到first_drv_open
   first_drv.dis文件里              insmod后
00000000 :       bf000000 t first_drv_open [first_drv]
00000018                         pc = bf000018
first_drv.dis文件中:
c014e6a8 :
//从这里可以看见 first_drv_open函数的栈信息,保存有4*4个字节
继承事业,薪火相传
