[求助]NiosII程序的EPCS配置
[求助]NiosII程序的EPCS配置
  我自己做了一个板子,上面有EPCS64和SRAM等,程序能够在SRAM中跑起来,但是我希望一上电程序能够自动运行,所以希望把程序烧到EPCS64中去,通过NiosII的Flash Program配置工具好像只把.SOF文件配置进去了,程序没有配置进去,因为重新上电后程序并没有运行,Flash Program的输出的信息如下,从中好像也没有输出什么错误啊,哪位大侠能帮我看看,或者能不能说一下配置这个东西有哪些地方需要特别注意的,谢谢啊
#!/bin/sh
# This file was automatically generated by the Nios II IDE Flash Programmer.
# It will be overwritten when the flash programmer options change.
cd G:/Graduation/Debug/LCD/software/lcd_test2/Debug
# Creating .flash file for the FPGA configuration
"$SOPC_KIT_NIOS2/bin/sof2flash" --epcs --input="G:/Graduation/Debug/LCD/lcd_test
.sof" --output="lcd_test.flash"
Info: *******************************************************************
Info: Running Quartus II Convert_programming_file
Info: Command: quartus_cpf --no_banner --convert --device=EPCS64 --option=lcd_te
st.opt G:/Graduation/Debug/LCD/lcd_test.sof lcd_test.pof
Info: Quartus II Convert_programming_file was successful. 0 errors, 0 warnings
    Info: Allocated 54 megabytes of memory during processing
    Info: Processing ended: Thu Jul 05 23:13:05 2007
    Info: Elapsed time: 00:00:07
Info: Command: quartus_cpf --no_banner --convert lcd_test.pof lcd_test.rpd
    Info: Allocated 51 megabytes of memory during processing
    Info: Processing ended: Thu Jul 05 23:13:11 2007
    Info: Elapsed time: 00:00:06
# Programming flash with the FPGA configuration
"$SOPC_KIT_NIOS2/bin/nios2-flash-programmer" --epcs --base=0x00002000 --sidp=0x0
0000808 --id=2135972589 --timestamp=1183647553  "lcd_test.flash"
Using cable "ByteBlasterII [LPT1]", device 1, instance 0x00
Resetting and pausing target processor: OK
Reading System ID at address 0x00000808: verified
              : Checksumming existing contents
00000000      : Verifying existing contents
00010000      : Verifying existing contents
00020000      : Verifying existing contents
00030000      : Verifying existing contents
00040000      : Verifying existing contents
00000000      : Reading existing contents
00010000      : Reading existing contents
00020000      : Reading existing contents
00030000      : Reading existing contents
00040000      : Reading existing contents
Checksummed/read 320kB in 21.2s
00000000 ( 0%): Erasing
00010000 (20%): Erasing
00020000 (40%): Erasing
00030000 (60%): Erasing
00040000 (80%): Erasing
Erased 320kB in 3.0s (106.6kB/s)
00000000 ( 0%): Programming
00010000 (20%): Programming
00020000 (40%): Programming
00030000 (60%): Programming
00040000 (80%): Programming
Programmed 285KB +35KB in 15.2s (21.0KB/s)
Did not attempt to verify device contents
Leaving target processor paused
# Creating .flash file for the project
"$SOPC_KIT_NIOS2/bin/elf2flash" --epcs --after="lcd_test.flash" --input="lcd_tes
t2.elf" --output="epcs_controller.flash"
# Programming flash with the project
0000808 --id=2135972589 --timestamp=1183647553  "epcs_controller.flash"
Checksummed/read 64kB in 4.2s
00040000 ( 0%): Erasing
Erased 64kB in 0.6s (106.6kB/s)
00040000 ( 0%): Programming
Programmed 34KB +30KB in 2.9s (22.0KB/s)
I
你采用sdk shell下载,不要用ide下载,试一下,下载到epcs中是很简单的啊。
在交流中前进,共同实现nios的应用。
