*以某种分类信息的形式把目标文件的数据组织(被分为几大块)输出 :
# objdump -x main
输入之后,输出信息类似如下:
main: file format elf32-i386
main
architecture: i386, flags 0x00000112:
EXEC_P, HAS_SYMS, D_PAGED
start address 0x08048580
Program Header:
PHDR off 0x00000034 vaddr 0x08048034 paddr 0x08048034 align 2**2
filesz 0x00000100 memsz 0x00000100 flags r-x
INTERP off 0x00000134 vaddr 0x08048134 paddr 0x08048134 align 2**0
filesz 0x00000013 memsz 0x00000013 flags r--
LOAD off 0x00000000 vaddr 0x08048000 paddr 0x08048000 align 2**12
filesz 0x00000914 memsz 0x00000914 flags r-x
LOAD off 0x00000914 vaddr 0x08049914 paddr 0x08049914 align 2**12
filesz 0x00000130 memsz 0x000001cc flags rw-
DYNAMIC off 0x0000092c vaddr 0x0804992c paddr 0x0804992c align 2**2
filesz 0x000000e0 memsz 0x000000e0 flags rw-
NOTE off 0x00000148 vaddr 0x08048148 paddr 0x08048148 align 2**2
filesz 0x00000020 memsz 0x00000020 flags r--
EH_FRAME off 0x000007e8 vaddr 0x080487e8 paddr 0x080487e8 align 2**2
filesz 0x0000003c memsz 0x0000003c flags r--
STACK off 0x00000000 vaddr 0x00000000 paddr 0x00000000 align 2**2
...省略...
Dynamic Section:
NEEDED libstdc++.so.6
NEEDED libm.so.6
NEEDED libgcc_s.so.1
NEEDED libc.so.6
INIT 0x80484c0
FINI 0x80487b8
GNU_HASH 0x8048168
...省略...
Version References:
required from libstdc++.so.6:
0x056bafd3 0x00 05 CXXABI_1.3
0x08922974 0x00 03 GLIBCXX_3.4
required from libc.so.6:
0x0d696910 0x00 04 GLIBC_2.0
0x09691f73 0x00 02 GLIBC_2.1.3
Sections:
Idx Name Size VMA LMA File off Algn
0 .interp 00000013 08048134 08048134 00000134 2**0
CONTENTS, ALLOC, LOAD, READONLY, DATA
1 .note.ABI-tag 00000020 08048148 08048148 00000148 2**2
2 .gnu.hash 00000030 08048168 08048168 00000168 2**2
3 .dynsym 000000d0 08048198 08048198 00000198 2**2
4 .dynstr 00000183 08048268 08048268 00000268 2**0
5 .gnu.version 0000001a 080483ec 080483ec 000003ec 2**1
...省略...
SYMBOL TABLE:
08048134 l d .interp 00000000 .interp
08048148 l d .note.ABI-tag 00000000 .note.ABI-tag
08048168 l d .gnu.hash 00000000 .gnu.hash
08048198 l d .dynsym 00000000 .dynsym
08048268 l d .dynstr 00000000 .dynstr
080483ec l d .gnu.version 00000000 .gnu.version
08048408 l d .gnu.version_r 00000000 .gnu.version_r
...省略...
这里可知,分别显示出各个段相关的信息。
*输出指定段的信息:
# objdump -j .text -S main
输入之后,输出类似如下:
Disassembly of section .text:
08048580 <_start>:
8048580: 31 ed xor %ebp,%ebp
8048582: 5e pop %esi
8048583: 89 e1 mov %esp,%ecx
8048585: 83 e4 f0 and $0xfffffff0,%esp
8048588: 50 push %eax
8048589: 54 push %esp
...省略...
这里,反汇编会用到类似的命令。
4 nm工具
这个命令可以用来查看库中的符号。
nm列出的符号有很多,常见的有三种,一种是在库中被调用,但并没有在库中定义(表明需要其他库支持),用U表示;一种是库中定义的函数,用T表示,这是最常见的;另外一种是所谓的“弱态”符号,它们虽然在库中被定义,但是可能被其他库中的同名符号覆盖,用W表示。
*假设开发者希望知道hello库中是否定义了 printf():
$nm libhello.so |grep printf
U printf
U表示符号printf被引用,但是并没有在函数内定义,由此可以推断,要正常使用hello库,必须有其它库支持。
5 ldd工具
ldd命令可以用来查看一个可执行文件或者库依赖哪些其他的文件。
*使用ldd命令查看hello依赖于哪些库:
$ldd hello
libc.so.6=>/lib/libc.so.6(0x400la000)
/lib/ld-linux.so.2=>/lib/ld-linux.so.2 (0x40000000)
这里,结合nm,从上面的结果可以继续查看printf最终在哪里被定义. |
