用的是SCI-B,问题是无法进入接收中断,接收引脚上有数据。
程序如下 :
- EALLOW ;
- GpioCtrlRegs.GPAMUX1.bit.GPIO9 = 0 ;
- GpioCtrlRegs.GPAMUX1.bit.GPIO11 = 0 ;
- GpioCtrlRegs.GPAMUX1.bit.GPIO14 = 0 ;
- GpioCtrlRegs.GPAMUX1.bit.GPIO15 = 0 ;
- GpioCtrlRegs.GPAMUX2.bit.GPIO18 = 2 ; //设置为CAN总线,而不是SCI-B
- GpioCtrlRegs.GPAMUX2.bit.GPIO19 = 2 ; //设置为CAN总线,而不是SCI-B
- GpioCtrlRegs.GPAMUX2.bit.GPIO22 = 3 ; //设置SCI-B引脚
- GpioCtrlRegs.GPAMUX2.bit.GPIO23 = 3 ; //设置SCI-B引脚
- EDIS ;
- ScibRegs.SCICCR.all = 0x07; //1位结束位,无奇偶校验,8位数据位
- ScibRegs.SCICTL1.all = 0x03; //使能transmitter和receiver,禁用sleep,屏蔽接收错误中断,复位SCI
- ScibRegs.SCIHBAUD = 0;
- ScibRegs.SCILBAUD = 80 & 0x00FF; //波特率=37500000/((80+1)*8)=57870
- ScibRegs.SCICTL2.all = 0x0002; //起用Receiver-buffer interrupt,禁用SCITXBUF-register interrupt
- ScibRegs.SCICTL1.all = 0x0023; //停止复位SCI
- PieVectTable.SCIRXINTB = &SCI_RX_ISR; //SCI接收中断处理程序
- PieCtrlRegs.PIEIER9.bit.INTx3 = 1; // SCIB接收中断使能
- IER |= 0x0100; // enable PIEIER9, and INT9
- EINT;
- ERTM;//全局中断使能
