STM32高级定时器-PWM简单使用
STM32高级定时器-PWM简单使用
高级定时器与通用定时器比较类似,下面是一个TIM1 的PWM 程序,TIM1是STM32唯一的高级定时器。共有4个通道有死区有互补。
先是配置IO脚:
      GPIO_InitTypeDef GPIO_InitStructure;
      GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
      GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
      GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
      GPIO_Init(GPIOA, &GPIO_InitStructure);
      GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13;
      GPIO_Init(GPIOB, &GPIO_InitStructure);
      RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1,ENABLE);
      RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
      RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
      TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
      TIM_OCInitTypeDef TIM_OCInitStructure;
void Tim1_Configuration(void)
    TIM_DeInit(TIM1); //重设为缺省值
TIM_TimeBaseStructure.TIM_Prescaler = 4000;      //预分频(时钟分频)72M/4000=18K
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;  //向上计数
TIM_TimeBaseStructure.TIM_Period = 144;       //装载值 18k/144=125hz 就是说向上加的144便满了
TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1;   //设置了时钟分割 不懂得不管
TIM_TimeBaseStructure.TIM_RepetitionCounter = 0x0;    //周期计数器值 不懂得不管
TIM_TimeBaseInit(TIM1,&TIM_TimeBaseStructure);   //初始化TIMx的时间基数单位
TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2;     //PWM模式2
TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;  //正向通道有效 PA8
TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable; //反向通道也有效 PB13
TIM_OCInitStructure.TIM_Pulse = 40;        //占空时间 144 中有40的时间为高,互补的输出正好相反
TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;   //输出极性
TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_Low;    //互补端的极性
TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Reset; //空闲状态下的非工作状态不管
TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCIdleState_Reset; //先不管
TIM_OC1Init(TIM1,&TIM_OCInitStructure);       //数初始化外设TIMx通道1这里2.0库为TIM_OCInit
