AT89C51程序
AT89C51程序
各位高手:大家好!
       小弟在使用AD0809和AT89C51芯片设计一个数字电压表,测量范围是直流0-5V。我在网上找了个程序,但是它的头文件是at89x52,不是51系列的。请问这个程序怎么改才可以适合我的设计内容呀!在此我先谢谢大家了。我的QQ是236135025,邮箱是baixianmin1983@126.com.程序如下:
#include <AT89X52.H>
unsigned char code dispbitcode[]={0xfe,0xfd,0xfb,0xf7,
                                  0xef,0xdf,0xbf,0x7f};
unsigned char code dispcode[]={0x3f,0x06,0x5b,0x4f,0x66,
                               0x6d,0x7d,0x07,0x7f,0x6f,0x00};
unsigned char dispbuf[8]={10,10,10,10,0,0,0,0};
unsigned char dispcount;
unsigned char getdata;
unsigned int temp;
unsigned char i;
sbit ST=P3^0;
sbit OE=P3^1;
sbit EOC=P3^2;
sbit CLK=P3^3;
void main(void)
  ST=0;
  OE=0;
  ET0=1;
  ET1=1;
  EA=1;
  TMOD=0x12;
  TH0=216;
  TL0=216;
  TH1=(65536-4000)/256;
  TL1=(65536-4000)%256;
  TR1=1;
  TR0=1;
  ST=1;
  ST=0;
  while(1)
      if(EOC==1)
          OE=1;
          getdata=P0;
          OE=0;
          temp=getdata*235;
          temp=temp/128;
          i=5;
          dispbuf[0]=10;
          dispbuf[1]=10;
          dispbuf[2]=10;
          dispbuf[3]=10;
          dispbuf[4]=10;
          dispbuf[5]=0;
          dispbuf[6]=0;
          dispbuf[7]=0;
          while(temp/10)
              dispbuf=temp%10;
              temp=temp/10;
              i++;
          dispbuf=temp;
          ST=1;
          ST=0;
void t0(void) interrupt 1 using 0
  CLK=~CLK;
void t1(void) interrupt 3 using 0
  P1=dispcode[dispbuf[dispcount]];
  P2=dispbitcode[dispcount];
  if(dispcount==7)
      P1=P1 | 0x80;
  dispcount++;
  if(dispcount==8)
      dispcount=0;
我终于明白了,应该将头文件改为AT89X51,而不是AT89C51
