以下例子为VHDL分配管脚的方法,仅供参考-
--* VHDL source constraint example
--* Pin Assignment for PLCC/QFP Pkg.
--* 2/01/2001
--* Lattice Semiconductor Corporation
--Target device = ispLSI5256VE-16LT128
--For BGA type syntax, see pinassgnBGA.syn
library ieee;
use ieee.std_logic_1164.all;
entity pinassgqfp is
port ( in5 :in std_logic;
in8 :in std_logic;
in10 :in std_logic;
o ut std_logic_vector (13 downto 11));
--The syntax of attribute LOC
--attribute LOC : string;
--attribute LOC of [SigName] : signal is "P[pin#]";
attribute LOC of in5 : signal is "P5";
attribute LOC of in8 : signal is "P8";
attribute LOC of in10 : signal is "P10";
attribute LOC of o : signal is "P13 P12 P11";
end;
architecture behavioral of pinassgqfp is
begin
o(11) <= in5 and in8;
o(12) <= in10 and in5;
o(13) <= in8 and in10;
end behavioral; |
