Kalman滤波C程序我就在上面公式的基础上实现了基本的Kalman滤波器,包括1维和2维状态的情况。先在头文件中声明1维和2维Kalman滤波器结构:
/* * FileName : kalman_filter.h * Author : xiahouzuoxin @163.com * Version : v1.0 * Date : 2014/9/24 20:37:01 * Brief : * * Copyright (C) MICL,USTB */#ifndef _KALMAN_FILTER_H#define _KALMAN_FILTER_H/* * NOTES: n Dimension means the state is n dimension, * measurement always 1 dimension *//* 1 Dimension */typedef struct { float x; /* state */ float A; /* x(n)=A*x(n-1)+u(n),u(n)~N(0,q) */ float H; /* z(n)=H*x(n)+w(n),w(n)~N(0,r) */ float q; /* process(predict) noise convariance */ float r; /* measure noise convariance */ float p; /* estimated error convariance */ float gain;} kalman1_state;/* 2 Dimension */typedef struct { float x[2]; /* state: [0]-angle [1]-diffrence of angle, 2x1 */ float A[2][2]; /* X(n)=A*X(n-1)+U(n),U(n)~N(0,q), 2x2 */ float H[2]; /* Z(n)=H*X(n)+W(n),W(n)~N(0,r), 1x2 */ float q[2]; /* process(predict) noise convariance,2x1 [q0,0; 0,q1] */ float r; /* measure noise convariance */ float p[2][2]; /* estimated error convariance,2x2 [p0 p1; p2 p3] */ float gain[2]; /* 2x1 */} kalman2_state; extern void kalman1_init(kalman1_state *state, float init_x, float init_p);extern float kalman1_filter(kalman1_state *state, float z_measure);extern void kalman2_init(kalman2_state *state, float *init_x, float (*init_p)[2]);extern float kalman2_filter(kalman2_state *state, float z_measure);#endif /*_KALMAN_FILTER_H*/我都给了有详细的注释,kalman1_state是状态空间为1维/测量空间1维的Kalman滤波器,kalman2_state是状态空间为2维/测量空间1维的Kalman滤波器。两个结构体都需要通过初始化函数初始化相关参数、状态值和均方差值。
/* * FileName : kalman_filter.c * Author : xiahouzuoxin @163.com * Version : v1.0 * Date : 2014/9/24 20:36:51 * Brief : * * Copyright (C) MICL,USTB */#include "kalman_filter.h"/* * @brief * Init fields of structure @kalman1_state. * I make some defaults in this init function: * A = 1; * H = 1; * and @q,@r are valued after prior tests. * * NOTES: Please change A,H,q,r according to your application. * * @inputs * state - Klaman filter structure * init_x - initial x state value * init_p - initial estimated error convariance * @outputs * @retval */void kalman1_init(kalman1_state *state, float init_x, float init_p){ state->x = init_x; state->p = init_p; state->A = 1; state->H = 1; state->q = 2e2;//10e-6; /* predict noise convariance */ state->r = 5e2;//10e-5; /* measure error convariance */}/* * @brief * 1 Dimension Kalman filter * @inputs * state - Klaman filter structure * z_measure - Measure value * @outputs * @retval * Estimated result */float kalman1_filter(kalman1_state *state, float z_measure){ /* Predict */ state->x = state->A * state->x; state->p = state->A * state->A * state->p + state->q; /* p(n|n-1)=A^2*p(n-1|n-1)+q */ /* Measurement */ state->gain = state->p * state->H / (state->p * state->H * state->H + state->r); state->x = state->x + state->gain * (z_measure - state->H * state->x); state->p = (1 - state->gain * state->H) * state->p; return state->x;}/* * @brief * Init fields of structure @kalman1_state. * I make some defaults in this init function: * A = {{1, 0.1}, {0, 1}}; * H = {1,0}; * and @q,@r are valued after prior tests. * * NOTES: Please change A,H,q,r according to your application. * * @inputs * @outputs * @retval */void kalman2_init(kalman2_state *state, float *init_x, float (*init_p)[2]){ state->x[0] = init_x[0]; state->x[1] = init_x[1]; state->p[0][0] = init_p[0][0]; state->p[0][1] = init_p[0][1]; state->p[1][0] = init_p[1][0]; state->p[1][1] = init_p[1][1]; //state->A = {{1, 0.1}, {0, 1}}; state->A[0][0] = 1; state->A[0][1] = 0.1; state->A[1][0] = 0; state->A[1][1] = 1; //state->H = {1,0}; state->H[0] = 1; state->H[1] = 0; //state->q = {{10e-6,0}, {0,10e-6}}; /* measure noise convariance */ state->q[0] = 10e-7; state->q[1] = 10e-7; state->r = 10e-7; /* estimated error convariance */}/* * @brief * 2 Dimension kalman filter * @inputs * state - Klaman filter structure * z_measure - Measure value * @outputs * state->x[0] - Updated state value, Such as angle,velocity * state->x[1] - Updated state value, Such as diffrence angle, acceleration * state->p - Updated estimated error convatiance matrix * @retval * Return value is equals to state->x[0], so maybe angle or velocity. */float kalman2_filter(kalman2_state *state, float z_measure){ float temp0 = 0.0f; float temp1 = 0.0f; float temp = 0.0f; /* Step1: Predict */ state->x[0] = state->A[0][0] * state->x[0] + state->A[0][1] * state->x[1]; state->x[1] = state->A[1][0] * state->x[0] + state->A[1][1] * state->x[1]; /* p(n|n-1)=A^2*p(n-1|n-1)+q */ state->p[0][0] = state->A[0][0] * state->p[0][0] + state->A[0][1] * state->p[1][0] + state->q[0]; state->p[0][1] = state->A[0][0] * state->p[0][1] + state->A[1][1] * state->p[1][1]; state->p[1][0] = state->A[1][0] * state->p[0][0] + state->A[0][1] * state->p[1][0]; state->p[1][1] = state->A[1][0] * state->p[0][1] + state->A[1][1] * state->p[1][1] + state->q[1]; /* Step2: Measurement */ /* gain = p * H^T * [r + H * p * H^T]^(-1), H^T means transpose. */ temp0 = state->p[0][0] * state->H[0] + state->p[0][1] * state->H[1]; temp1 = state->p[1][0] * state->H[0] + state->p[1][1] * state->H[1]; temp = state->r + state->H[0] * temp0 + state->H[1] * temp1; state->gain[0] = temp0 / temp; state->gain[1] = temp1 / temp; /* x(n|n) = x(n|n-1) + gain(n) * [z_measure - H(n)*x(n|n-1)]*/ temp = state->H[0] * state->x[0] + state->H[1] * state->x[1]; state->x[0] = state->x[0] + state->gain[0] * (z_measure - temp); state->x[1] = state->x[1] + state->gain[1] * (z_measure - temp); /* Update @p: p(n|n) = [I - gain * H] * p(n|n-1) */ state->p[0][0] = (1 - state->gain[0] * state->H[0]) * state->p[0][0]; state->p[0][1] = (1 - state->gain[0] * state->H[1]) * state->p[0][1]; state->p[1][0] = (1 - state->gain[1] * state->H[0]) * state->p[1][0]; state->p[1][1] = (1 - state->gain[1] * state->H[1]) * state->p[1][1]; return state->x[0];}其实,Kalman滤波器由于其递推特性,实现起来很简单。但调参有很多可研究的地方,主要需要设定的参数如下:
- init_x:待测量的初始值,如有中值一般设成中值(如陀螺仪)
- init_p:后验状态估计值误差的方差的初始值
- q:预测(过程)噪声方差
- r:测量(观测)噪声方差。以陀螺仪为例,测试方法是:保持陀螺仪不动,统计一段时间内的陀螺仪输出数据。数据会近似正态分布,按3σ原则,取正态分布的(3σ)^2作为r的初始化值。
其中q和r参数尤为重要,一般得通过实验测试得到。
找两组声阵列测向的角度数据,对上面的C程序进行测试。一维Kalman(一维也是标量的情况,就我所知,现在网上看到的代码大都是使用标量的情况)和二维Kalman(一个状态是角度值,另一个状态是向量角度差,也就是角速度)的结果都在图中显示。这里再稍微提醒一下:状态量不要取那些能突变的量,如加速度,这点在文章“从牛顿到卡尔曼”一小节就提到过。
Matlab绘出的跟踪结果显示:
Kalman滤波结果比原信号更平滑。但是有椒盐突变噪声的地方,Kalman滤波器并不能滤除椒盐噪声的影响,也会跟踪椒盐噪声点。因此,推荐在Kalman滤波器之前先使用中值滤波算法去除椒盐突变点的影响。
上面所有C程序的源代码及测试程序都公布在我的github上,希望大家批评指正其中可能存在的错误。 |
