AR模型更新(2)
AR模型更新(2)
  • * ar_model.c
  • *  Created on: 2013-8-11
  • *      Author: monkeyzx
  • #include <stdio.h>
  • #include <stdlib.h>
  • #include <math.h>
  • //#include "msp.h"
  • #include "ar_model.h"
  • #include "time.h"
  • float mabs(complex a)
  •      float m;
  •      m=a.real*a.real+a.imag*a.imag;
  •      m=sqrt(m);
  •      return(m);
  •   Routine MCORRE1:To estimate the biased cross-correlation function
  •   of complex arrays x and y. If y=x,then it is auto-correlation.
  •   input parameters:
  •      x  :n dimensioned complex array.
  •      y  :n dimensioned complex array.
  •      n  :the dimension of x and y.
  •      lag:point numbers of correlation.
  •   output parameters:
  •      r  :lag dimensioned complex array, the correlation function is
  •          stored in r(0) to r(lag-1).
  •                                       in Chapter 1 and 11
  • void maryuwa(complex x[],complex a[],complex r[],int n,int ip,
  • float *ep,int *ierror)
  •     complex sum;
  •     int i,k;
  •     float r0;
  •     *ierror=1;
  •     mcorre1(x,x,r,n,ip+1);
  •     a[0].real=1.0;
  •     a[0].imag=0.0;
  •     r0=r[0].real;
  •     a[1].real=-r[1].real/r0;
  •     a[1].imag=-r[1].imag/r0;
  •     *ep=r0*(1.0f-pow(mabs(a[1]),2));
  •     for(k=2;k<=ip;k++) {
  •         sum.real=0.;
  •         sum.imag=0.;
  •         for(i=1;i<k;i++) {
  •             sum.real+=r[k-i].real*a.real-r[k-i].imag*a.imag;
  •             sum.imag+=r[k-i].real*a.imag+r[k-i].imag*a.real;
  •         sum.real+=r[k].real;
  •         sum.imag+=r[k].imag;
  •         a[k].real=-sum.real/(*ep);
  •         a[k].imag=-sum.imag/(*ep);
  •         (*ep)*=1.-pow(mabs(a[k]),2);
  •         if(*ep<=0.0)
  •             return;
  •             x.real=a.real+a[k-i].real*a[k].real+
  •                     a[k-i].imag*a[k].imag;
  •             x.imag=a.imag+a[k-i].real*a[k].imag-
  •                     a[k-i].imag*a[k].real;
  •             a.real=x.real;
  •             a.imag=x.imag;
  •     *ierror=0;
  •   routinue mrelfft:To perform  split-radix DIF fft algorithm.
  •   input parameters:
  •    xr,xi:real and image part of complex data for DFT/IDFT,n=0,...,N-1
  •    N    ata point number of DFT compute .
  •    isign:Transform direction disignator ,
  •                isign=-1: For Forward Transform.
  •                isign=+1: For Inverse Transform.
  •    xr,xi:real and image part of complex result of DFT/IDFT,n=0,...,N-1
  •   Note: N  must be a power of 2 .
  •                                        in chapter 5
  • void mrelfft(float xr[],float xi[],int n,int isign)
  •     float e,es,cc1,ss1,cc3,ss3,r1,s1,r2,s2,s3,xtr,xti,a,a3;
  •     int m,n2,n4,j,k,is,id,i0,i1,i2,i3,n1,i,nn;
  •     for(m=1;m<=16;m++) {
  •         nn=pow(2,m);
  •         if(n==nn)break;
  •     if(m>16) {
  • #ifdef _DEBUG
  •         printf(" N is not a power of 2 ! \n");
  • #endif
  •         return;
  •     n2=n*2;
  •     es=-isign*atan(1.0)*8.0;
  •     for(k=1;k<m;k++) {
  •         n2=n2/2;
  •         n4=n2/4;
  •         e=es/n2;
  •         a=0.0;
  •         for(j=0;j<n4;j++) {
  •             a3=3*a;
  •             cc1=cos(a);
  •             ss1=sin(a);
  •             cc3=cos(a3);
  •             ss3=sin(a3);
  •             a=(j+1)*e;
  •             is=j;
  •             id=2*n2;
  •             do {
  •                 for(i0=is;i0<n;i0+=id) {
  •                     i1=i0+n4;
  •                     i2=i1+n4;
  •                     i3=i2+n4;
  •                     r1=xr[i0]-xr[i2];
  •                     s1=xi[i0]-xi[i2];
  •                     r2=xr[i1]-xr[i3];
  •                     s2=xi[i1]-xi[i3];
  •                     xr[i0]+=xr[i2];
  •                     xi[i0]+=xi[i2];
  •                     xr[i1]+=xr[i3];
  •                     xi[i1]+=xi[i3];
  •                     if(isign!=1) {
  •                         s3=r1-s2;
  •                         r1=r1+s2;
  •                         s2=r2-s1;
  •                         r2=r2+s1;
  •                     } else {
  •                             s3=r1+s2;
  •                             r1=r1-s2;
  •                             s2=-r2-s1;
  •                             r2=-r2+s1;
  •                     xr[i2]=r1*cc1-s2*ss1;
  •                     xi[i2]=-s2*cc1-r1*ss1;
  •                     xr[i3]=s3*cc3+r2*ss3;
  •                     xi[i3]=r2*cc3-s3*ss3;
  •                 is=2*id-n2+j;
  •                 id=4*id;
  •             }while(is<n-1);
  • /*   ------------ special last stage -------------------------*/
  •     is=0;
  •     id=4;
  •     do {
  •             i1=i0+1;
  •             xtr=xr[i0];
  •             xti=xi[i0];
  •             xr[i0]=xtr+xr[i1];
  •             xi[i0]=xti+xi[i1];
  •             xr[i1]=xtr-xr[i1];
  •             xi[i1]=xti-xi[i1];
  •         is=2*id-2;
  •         id=4*id;
  •     } while(is<n-1);
  •     j=1;
  •     n1=n-1;
  •     for(i=1;i<=n1;i++) {
  •         if(i<j) {
  •             xtr=xr[j-1];
  •             xti=xi[j-1];
  •             xr[j-1]=xr[i-1];
  •             xi[j-1]=xi[i-1];
  •             xr[i-1]=xtr;
  •             xi[i-1]=xti;
  •         k=n/2;
  •         while(1) {
  •             if(k>=j)break;
  •             j=j-k;
  •             k=k/2;
  •         j=j+k;
  •     if(isign==-1) return;
  •     for(i=0;i<n;i++) {
  •         xr/=n;
  •         xi/=n;
