Please enter your Password: [你上网的拨号密码]
Please re-enter your Password: [你上网的拨号密码]
#口令
#请输入你的口令:
#请再次输入你的口令:
USERCTRL
Please enter ´yes´ (two letters, lower-case.) if you want to allow
normal user to start or stop DSL connection (default yes): [no]
#决定非“root”帐号能否启动和停止连接。
FIREWALLING
Please choose the firewall rules to use. Note that these rules are
very basic. You are strongly encouraged to use a more sophisticated
firewall setup; however, these will provide basic security. If you
are running any servers on your machine, you must choose ´NONE´ and
set up firewalling yourself. Otherwise, the firewall rules will deny
access to all standard servers like Web, e-mail, ftp, etc. If you
are using SSH, the rules will block outgoing SSH connections which
allocate a privileged source port.
#防火墙相关事宜。
The firewall choices are:
0 - NONE: This script will not set any firewall rules. You are responsible
for ensuring the security of your machine. You are STRONGLY
recommended to use some kind of firewall rules.
1 - STANDALONE: Appropriate for a basic stand-alone web-surfing workstation
2 - MASQUERADE: Appropriate for a machine acting as an Internet gateway
for a LAN
Choose a type of firewall (0-2): [0]
#防火墙选项:
#0 - 什么也没有。
#1 - ?
#2 - IP伪装?
Start this connection at boot time
Do you want to start this connection at boot time?
Please enter no or yes (default no):[yes]
#希望在启动时建立连接吗?
#(默认不)
Ethernet Interface: eth0
User name: typhoon
Activate-on-demand: No
DNS: Do not adjust
Firewalling: NONE
User Control: no
#刚才设置的连接信息,还没生效,依次为:
#以太网界面:
#用户名:
#使用连接守护进程:
#域名服务器:
#防火墙:
#用户控制权:
Accept these settings and adjust configuration files (y/n)? [y]
#是否使用这个配置(是/否)?
2.3 声音
音乐听不成电影看字幕,没有声音让人很不爽。
把你计算机的耳机、喇叭或音箱声音声音调大。以“root”身份登录系统,执行命令“xsndconf”进行设置。启动图形界面程序的命令可以在“终端”里执行,也可以在用“Alt”键加“F2”键开的小命令行里执行。
一般推荐用Alsa而不是内核直接支持。注意声卡自动检查时间可能超过半分钟。一切正常的话,会出声音。
2.4 访问其他文件系统
网上去了,喇叭出声了。看看桌面,恩,有个“MP3播放器”的图标。要听歌,可是歌都在Window$/DOS分区,怎么办?
2.4.1 准备工作
打开“我的电脑”,看到“C”、“D”之类的盘符了吗?当然,你可以如此访问这些分区,但是仅限于你直接访问。
类似Window$下那个著名的MP3播放器,你桌面上的“MP3播放器”也可以用“打开”一类对话框来添加播放列表。然而你会发现,“打开”对话框中的那些盘符统统无效!
这不是程序错误。红旗4.0擅自变动了Linux的分区访问规则,本意是方便使用者,实际上却造成了麻烦。那几个分区其实不在那里,盘符的图标可以看作是打开那个分区文件夹用的小程序。
尽管修正这个毛病会暂时麻烦你动动手,但你是否为这个毛病感到郁闷?来吧,动手修正这个毛病,修正完后一切都清净!尝试一下Linux的规则,以后你就不需要关心分区了,除非哪天那个分区真的空间紧张。
以“root”身份登录系统。找到这个文件:“/etc/rc.d/init.d/ls-disk”,正是这个自作聪明的脚本在作崇。把它改名吧,否则下次启动时它还会做些手脚让你不自在。
再开“我的电脑”,把里面象征硬盘的盘符全部删掉。谢谢红旗公司的好意,可是它们确实带来了麻烦。刚才的那个脚本在启动时会检查这些盘符,如果不让它失效,下次启动盘符这里又在这里了。
那么,那些分区究竟在哪里?请开“终端”,执行“mount”。前面讲过Linux的分区编号规则,你对着看看。
“咦?这个文件夹被保护了!”没关系,右键点,找“文件保护”,消掉吧。这种把戏,谁也哄不了,以后见到,统统取消,最多改成提示!
2.4.2 启动自动加载分区
没有了“ls-disk”的干扰,自主权回到你的手中,你想把那些分区挂在个目录,就能挂在那里。“ls-disk”能在系统启动时自动加载这些分区,但是离开它同样能办到,这个文件掌管这摊事物:“/etc/fstab”。
去“/etc”,找到“fstab”。右键点->“打开方式”->“其他”。在询问对话框上部输入“kwrite”,把底下的“记住该文件类型的应用程序关联”,再“确定”。从此以后,绝大多数文本文件都会用“kwrite”打开。这是个比Window$记事本强很多的程序。
“哇,我不喜欢这样,字体太小,又不整齐!”好,碰到一个问题解决一个。编辑器顶上的菜单条->“设置”->“配置编辑器”->“字体”。经过仔细观察,字体选“MonoSpace”,大小“12”为好,这样一个汉字或中文标点的宽度正好等于两个数字、字母或其他字符的宽度,很标准。 |
