powerpc linux下dts解析过程详解更新
四. 将allnodes显示在/proc/device-tree目录下start_kernel() -->
#ifdef CONFIG_PROC_FS
proc_root_init(); -->
#endif
#ifdef CONFIG_PROC_DEVICETREE
#endif
proc_device_tree_add_node(root, proc_device_tree);
此时将在/proc/device-tree目录下生成设备节点
# ls -al /proc/device-tree
五. of_platform_bus_type的注册/初始化 -------------------------------------------------------------------
arch/powerpc/kernel/of_platform.c
struct bus_type of_platform_bus_type = {
       .uevent   = of_device_uevent,
EXPORT_SYMBOL(of_platform_bus_type);
static int __init of_bus_driver_init(void)
   return of_bus_type_init(&of_platform_bus_type, "of_platform");
postcore_initcall(of_bus_driver_init);
of_platform_bus_type总线注册完毕。
此时/sys/bus/目录下将会有of_platform
六. 将allnodes设备节点添加到总线of_platform_bus_type
arch/powerpc/platform/85xx/mpc85Xx_ads.c
static int __init declare_of_platform_devices(void)
of_platform_bus_probe(NULL, of_bus_ids, NULL);
return 0;
machine_device_initcall(mpc85xx_ads, declare_of_platform_devices);
declare_of_platform_devices() --> of_platform_bus_probe(NULL, of_bus_ids, NULL)
遍历第一步中在内存中生成链表的所有soc的子节点,将所有的soc子节点设备添加到of_platform总线。
int of_platform_bus_probe(struct device_node *root,
const struct of_device_id *matches,
struct device *parent)
struct device_node *child;
struct of_device *dev;
int rc = 0;
if (matches == NULL)
matches = of_default_bus_ids;
if (matches == OF_NO_DEEP_PROBE)
return -EINVAL;
if (root == NULL)
root = of_find_node_by_path("/");
else
of_node_get(root);
pr_debug("of_platform_bus_probe()\n");
pr_debug(" starting at: %s\n", root->full_name);
/* Do a self check of bus type, if there's a match, create
* children
if (of_match_node(matches, root)) {
pr_debug(" root match, create all sub devices\n");
dev = of_platform_device_create(root, NULL, parent);
if (dev == NULL) {
rc = -ENOMEM;
goto bail;
pr_debug(" create all sub busses\n");
rc = of_platform_bus_create(root, matches, &dev->dev);
goto bail;
for_each_child_of_node(root, child) {
if (!of_match_node(matches, child))
continue;
pr_debug("  match: %s\n", child->full_name);
dev = of_platform_device_create(child, NULL, parent);
if (dev == NULL)
rc = -ENOMEM;
else
rc = of_platform_bus_create(child, matches, &dev->dev);
if (rc) {
of_node_put(child);
break;
bail:
of_node_put(root);
return rc;
EXPORT_SYMBOL(of_platform_bus_probe);
--> of_platform_device_create--> of_device_register() --> device_add()
of_platform总线上的所有设备添加完毕,e0024000.ethernet,e0024520.mdio等设备现在都在总线上。至此设备节点将出现在/sys/devices/platform/
七、实例 1、mdio总线的注册
/driver/net/phy_device.c
subsys_initcall(phy_init)
phy_init --> mdio_bus_init --> bus_register(&mdio_bus_type)
总线注册后,在总线上注册了一个默认的phy的驱动 genphy_driver:
.phy_id      = 0xffffffff,
.phy_id_mask = 0xffffffff,
.name        = "Generic phy",
mdio总线注册完毕。
/sys/bus/mdio
2、 mdio总线上驱动的添加
/driver/net/phy/marvell.c
module_init(marvell_init)
marvell_init() -->
phy_driver_register(&marvell_drivers) -->
driver_register()
前面第三步,注册mdio总线后,已经添加了一个默认的phy的驱动,现在要将所有的phy驱动添加到总线上,这里将所有的marvell的phy都添加。
这步过后,内核的/sys/bus/mdio/driver里面就有了各种phy的驱动,但这时还没有和具体的设备绑定。
3、 of_platform总线上mdio设备驱动(该驱动的目的是在mdio总线上添加phy设备)的添加,并绑定设备:e0024520.mdio和e0025520.mdio
/driver/net/fsl_pq_mdio.c
module_init(fsl_pq_mdio_init)
fsl_pq_mdio_init --> of_register_platform_driver(&fsl_pq_mdio_driver) --> of_register_driver --> driver_register --> bus_add_driver --> driver_attach
遍历整个of_platform总线,寻找与之相匹配的设备,找到e0024520.mdio
driver_attach --> __driver_attach --> driver_match_device
将driver的match_table里的信息和dev_nod中的做比较,若符合就进入driver的probe,也就是fsl_pq_mdio_probe。
现在of_platform总线上的设备e0024520.mdio和e0025520.mdio已经绑定了驱动。
4、 mdio总线上的设备的添加,寻找并绑定相应的驱动。
fsl_pq_mdio_probe --> of_mdiobus_register --> phy_device_register --> device_register(&phydev->dev) --> device_add --> bus_probe_device --> device_attach -->bus_for_each_drv
扫描mdio总线上的所有的驱动,若找到匹配的,就绑定,并probe。
__device_attach --> driver_probe_device --> really_probe --> phy_probe
将所有的phy和tbi-phy的设备都添加到mdio总线上,并且两个phy设备和两个tbi-phy设备都会根据其自己的phyID找到各自的驱动
