BUG: scheduling while atomic 分析
遇到一个典型的schedule问题。
- <3>[26578.636839] C1 [ swapper/1] BUG: scheduling while atomic: swapper/1/0/0x00000002
- <6>[26578.636869] C0 [ kworker/u:1] CPU1 is up
- <4>[26578.636900] C1 [ swapper/1] Modules linked in: bcm15500_i2c_ts
- <4>[26578.636961] C1 [ swapper/1] [<c00146d0>] (unwind_backtrace+0x0/0x11c) from [<c0602684>] (__schedule+0x70/0x6e0)
- <4>[26578.636991] C1 [ swapper/1] [<c0602684>] (__schedule+0x70/0x6e0) from [<c06030ec>] (schedule_preempt_disabled+0x14/0x20)
- <4>[26578.637052] C1 [ swapper/1] [<c06030ec>] (schedule_preempt_disabled+0x14/0x20) from [<c000f05c>] (cpu_idle+0xf0/0x104)
- <4>[26578.637083] C1 [ swapper/1] [<c000f05c>] (cpu_idle+0xf0/0x104) from [<c05e98e0>] (cpu_die+0x2c/0x5c)
- <3>[26578.637510] C1 [ swapper/1] BUG: scheduling while atomic: swapper/1/0/0x00000002
- <4>[26578.637510] C1 [ swapper/1] Modules linked in: bcm15500_i2c_ts
- <4>[26578.637602] C1 [ swapper/1] [<c00146d0>] (unwind_backtrace+0x0/0x11c) from [<c0602684>] (__schedule+0x70/0x6e0)
- <4>[26578.637663] C1 [ swapper/1] [<c0602684>] (__schedule+0x70/0x6e0) from [<c06030ec>] (schedule_preempt_disabled+0x14/0x20)
- <4>[26578.637724] C1 [ swapper/1] [<c06030ec>] (schedule_preempt_disabled+0x14/0x20) from [<c000f05c>] (cpu_idle+0xf0/0x104)
- <4>[26578.637754] C1 [ swapper/1] [<c000f05c>] (cpu_idle+0xf0/0x104) from [<c05e98e0>] (cpu_die+0x2c/0x5c)
- <3>[26578.648069] C1 [ swapper/1] BUG: scheduling while atomic: swapper/1/0/0x00000002
查看源代码
- * __schedule() is the main scheduler function.
- static
void __sched __schedule(void) - {
- struct task_struct *prev, *next;
- unsigned long *switch_count;
- struct rq *rq;
- int cpu;
- need_resched:
- preempt_disable();
- cpu = smp_processor_id();
- rq = cpu_rq(cpu);
- rcu_note_context_switch(cpu);
- prev = rq->curr;
- schedule_debug(prev);
- * Print scheduling while atomic bug:
- static
noinline
void __schedule_bug(struct task_struct *prev) - {
- if (oops_in_progress)
- return;
- printk(KERN_ERR "BUG: scheduling while atomic: %s/%d/0x%08x\n",
- prev->comm, prev->pid, preempt_count());
- debug_show_held_locks(prev);
- print_modules();
- if (irqs_disabled())
- print_irqtrace_events(prev);
- dump_stack();
- * Various schedule()-time debugging checks and statistics:
- static
inline
void schedule_debug(struct task_struct *prev) - {
- * Test if we are atomic. Since do_exit() needs to call into
- * schedule() atomically, we ignore that path for now.
- * Otherwise, whine if we are scheduling when we should not be.
- if (unlikely(in_atomic_preempt_off() && !prev->exit_state))
- __schedule_bug(prev);
- rcu_sleep_check();
- profile_hit(SCHED_PROFILING, __builtin_return_address(0));
- schedstat_inc(this_rq(), sched_count);
可以看出, 满足如下条件将会打印该出错信息
- unlikely(in_atomic_preempt_off() && !prev->exit_state
为0表示TASK_RUNNING状态,当前进程在运行; 并且处于原子状态,,那么就不能切换给其它的进程
- <code class="cpp plain">Linux/include/linux/sched.h </code>
- * Task state bitmask. NOTE! These bits are also
- * encoded in fs/proc/array.c: get_task_state().
- * We have two separate sets of flags: task->state
- * is about runnability, while task->exit_state are
- * about the task exiting. Confusing, but this way
- * modifying one set can't modify the other one by
- * mistake.
- #define TASK_RUNNING 0
- #define TASK_INTERRUPTIBLE 1
- #define TASK_UNINTERRUPTIBLE 2
- #define __TASK_STOPPED 4
- #define __TASK_TRACED 8
- /* in tsk->exit_state */
- #define EXIT_ZOMBIE 16
- #define EXIT_DEAD 32
- /* in tsk->state again */
- #define TASK_DEAD 64
- #define TASK_WAKEKILL 128
- #define TASK_WAKING 256
- #define TASK_STATE_MAX 512
- kernel/include/linux/hardirq.h
- #if defined(CONFIG_PREEMPT_COUNT)
- # define PREEMPT_CHECK_OFFSET 1
- #else
- # define PREEMPT_CHECK_OFFSET 0
- #endif
- * Are we running in atomic context? WARNING: this macro cannot
- * always detect atomic context; in particular, it cannot know about
- * held spinlocks in non-preemptible kernels. Thus it should not be
- * used in the general case to determine whether sleeping is possible.
- * Do not use in_atomic() in driver code.
- #define in_atomic() ((preempt_count() & ~PREEMPT_ACTIVE) != 0)
- * Check whether we were atomic before we did preempt_disable():
- * (used by the scheduler, *after* releasing the kernel lock)
- #define in_atomic_preempt_off() \
- ((preempt_count() & ~PREEMPT_ACTIVE) != PREEMPT_CHECK_OFFSET)
结论整理
linux内核打印"BUG: scheduling while atomic"和"bad: scheduling from the idle thread"错误的时候,
通常是在中断处理函数中调用了可以休眠的函数,如semaphore,mutex,sleep之类的可休眠的函数,
而linux内核要求在中断处理的时候,不允许系统调度,不允许抢占,要等到中断处理完成才能做其他事情。
因此,要充分考虑中断处理的时间,一定不能太久。
另外一个能产生此问题的是在idle进程里面,做了不该做的事情。现在Linux用于很多手持式设备,为了降低功耗,
通常的作法是在idle进程里面降低CPU或RAM的频率、关闭一些设备等等。要保证这些动作的原子性才能确保
不发生"bad: scheduling from the idle thread"这样的错误!
禁止内核抢占是指内核不会主动的抢占你的process,但是现在是你在自己的程序中主动call schedule(),
kernel并不能阻止你这么作。
Scheduling while atomic" means that a thread has called schedule() during an operation which is supposed to be atomic (ie uninterrupted).
- 190 NOTE: ***** WARNING *****
- 191 NEVER SLEEP IN A COMPLETION HANDLER. These are normally called
- 192 during hardware interrupt processing. If you can, defer substantial
- 193 work to a tasklet (bottom half) to keep system latencies low. You'll
- 194 probably need to use spinlocks to protect data structures you manipulate
- 195 in completion handlers.
- GFP_ATOMIC is used when
- (a) you are inside a completion handler, an interrupt, bottom half, tasklet or timer, or
- (b) you are holding a spinlock or rwlock (does not apply to semaphores), or
- (c) current->state != TASK_RUNNING, this is the case only after you've changed it.
