- `timescale 1ns / 1ps
- // Company:
- // Engineer:
- // Create Date: 20:53:17 10/25/2013
- // Design Name: CPU
- // Module Name: F:/Digital_Practice/Practice/CPU/stimulus2.v
- // Project Name: CPU
- // Revision 0.01 - File Created
- // state macro define
- `define idle 1'b0
- `define exec 1'b1
- // instruction macro define
- `define NOP 5'b00000
- `define HALT 5'b00001
- `define LOAD 5'b00010
- `define STORE 5'b00011
- `define SLL 5'b00100
- `define SLA 5'b00101
- `define SRL 5'b00110
- `define SRA 5'b00111
- `define ADD 5'b01000
- `define ADDI 5'b01001
- `define SUB 5'b01010
- `define SUBI 5'b01011
- `define CMP 5'b01100
- `define AND 5'b01101
- `define OR 5'b01110
- `define XOR 5'b01111
- `define LDIH 5'b10000
- `define ADDC 5'b10001
- `define SUBC 5'b10010
- `define JUMP 5'b11000
- `define JMPR 5'b11001
- `define BZ 5'b11010
- `define BNZ 5'b11011
- `define BN 5'b11100
- `define BNN 5'b11101
- `define BC 5'b11110
- `define BNC 5'b11111
- // general register
- `define gr0 3'b000
- `define gr1 3'b001
- `define gr2 3'b010
- `define gr3 3'b011
- `define gr4 3'b100
- `define gr5 3'b101
- `define gr6 3'b110
- `define gr7 3'b111
- module stimulus2;
- // Inputs
- reg reset;
- reg enable;
- reg start;
- reg clock;
- reg [15:0] i_datain;
- reg [15:0] d_datain;
- // Outputs
- wire d_we;
- wire [7:0] i_addr;
- wire [7:0] d_addr;
- wire [15:0] d_dataout;
- // Instantiate the Unit Under Test (UUT)
- CPU uut (
- .reset(reset),
- .enable(enable),
- .start(start),
- .clock(clock),
- .i_datain(i_datain),
- .d_datain(d_datain),
- .d_we(d_we),
- .i_addr(i_addr),
- .d_addr(d_addr),
- .d_dataout(d_dataout)
- initial begin
- $dumpfile("CPU.vcd");
- $dumpvars(1,stimulus2.uut);
- // Initialize Inputs
- clock = 0;
- reset = 0;
- start = 0;
- enable = 0;
- d_datain = 0;
- i_datain = 0;
- // Wait 100 ns for global reset to finish
- #10;
- // Add stimulus here
- //************* test pattern *************//
- $display("LOAD,ADD,HALT,SUB,STORE");
- $display("pc: id_ir :reg_A:reg_B:ALUo:reg_C:da:dd :w:reC1:gr1 :gr2 :gr3 :exir:mmir:wbir:smdr");
- $monitor("%h:%b:%h :%h :%h :%h :%h:%h:%b:%h:%h:%h:%h:%h:%h:%h:%h:%b",
- uut.pc, uut.id_ir, uut.reg_A, uut.reg_B, uut.ALUo,uut.reg_C,
- d_addr, d_dataout, d_we, uut.reg_C1, uut.gr[1], uut.gr[2], uut.gr[3],uut.ex_ir,uut.mem_ir,uut.wb_ir,uut.smdr,uut.zf);
- enable <= 1; start <= 0; i_datain <= 0; d_datain <= 0; /*select_y <= 0;*/
- #10 reset <= 0;
- #10 reset <= 1;
- #10 enable <= 1;
- #10 start <= 1;
- #10 start <= 0;
- i_datain <= {`LOAD, `gr1, 1'b0, `gr0, 4'b0000};
- d_datain <= 16'hfC00; // 3 clk later from LOAD
- #10 i_datain <= {`LOAD, `gr2, 1'b0, `gr0, 4'b0001};
- #10;//阻塞相当于延迟一个周期取i_datain
- #10 i_datain <= {`ADD, `gr3, 1'b0, `gr1, 1'b0, `gr2};
- d_datain <= 16'h10AB;
- #10 i_datain <= {`ADDC, `gr3, 1'b0, `gr2, 1'b0, `gr1};
- #10 i_datain <= {`SUB, `gr3, 1'b0, `gr2, 1'b0, `gr1};
- #10 i_datain <= {`SUBC, `gr3, 1'b0, `gr2, 1'b0, `gr1};
- #10 i_datain <= {`STORE, `gr3, 1'b0, `gr0, 4'b0010};
- //#10 i_datain <= {`HALT, 11'b000_0000_0000};
- #10 start <= 1;
- #10 start <= 0;
- $display("SLL,SRA,SLA,SRL");
- $display("pc: id_ir :reg_A:reg_B:ALUo:reg_C:da:dd :w:reC1:gr1 :gr2 :gr3 :ddin:exir:mmir:wbir:smdr");
- i_datain <= {`SLL, `gr3, 1'b0, `gr1, 4'b0010};
- #10 i_datain <= {`SRA, `gr3, 1'b0, `gr3, 4'b0010};
- #10 i_datain <= {`SLA, `gr3, 1'b0, `gr2, 4'b011};
- #10 i_datain <= {`SRL, `gr3, 1'b0, `gr2, 4'b0001};
- #10 start <= 1;
- #10 start <= 0;
- $display("LDIH,SUBI,BZ,AND,OR,XOR");
- $display("pc: id_ir :reg_A:reg_B:ALUo:reg_C:da:dd :w:reC1:gr1 :gr2 :gr3 :ddin:exir:mmir:wbir:smdr:zf");
- i_datain <= {`LDIH, `gr1, 8'b0000_0100 };
- #10 i_datain <= {`BZ, `gr3, 4'b0000, 4'b0001 };
- #10 i_datain <= {`ADDI, `gr1, 4'b1111, 4'b1111 };
- #10 i_datain <= {`AND, `gr3, 1'b0,`gr1, 1'b0,`gr2 };
- #10 i_datain <= {`OR, `gr3,1'b0, `gr1,1'b0, `gr2 };
- #10 i_datain <= {`XOR, `gr3, 1'b0,`gr1, 1'b0,`gr2 };
- #10 i_datain <= {`HALT, 11'b000_0000_0000};
- end
- always #5 clock = ~clock;
- endmodule
