以下是对at89c0808c加密芯片的memory test zone 读写数据的程序,但是有些数据读写正确,有些数据读写就错误,请指点!! #include"string.h" #include <stdio.h> #include "altera_avalon_pio_regs.h" #include "system.h" #include "time.h" #define Set_SDA IOWR_ALTERA_AVALON_PIO_DATA(SDA_BASE, 0x1) #define Clr_SDA IOWR_ALTERA_AVALON_PIO_DATA(SDA_BASE, 0x0) #define Set_SCL IOWR_ALTERA_AVALON_PIO_DATA(SCL_BASE, 0x1) #define Clr_SCL IOWR_ALTERA_AVALON_PIO_DATA(SCL_BASE, 0x0) void delay1us() {int a1; for(a1=0;a1<50;a1++); }
void delay1ms() {int a2; for(a2=0;a2<50000;a2++); } void I2C_Start(void) { IOWR_ALTERA_AVALON_PIO_DIRECTION(SDA_BASE, 0x1); IOWR_ALTERA_AVALON_PIO_DIRECTION(SCL_BASE, 0x1); Set_SDA; Set_SCL; delay1us(); Clr_SDA; delay1us(); Clr_SCL; delay1us(); } void I2C_Stop(void) { IOWR_ALTERA_AVALON_PIO_DIRECTION(SDA_BASE, 0x1); IOWR_ALTERA_AVALON_PIO_DIRECTION(SCL_BASE, 0x1); Clr_SDA; Clr_SCL; delay1us(); Clr_SDA; Set_SCL; delay1us(); Set_SDA; delay1us(); } void I2C_Ack(void) { IOWR_ALTERA_AVALON_PIO_DIRECTION(SDA_BASE, 0x1); IOWR_ALTERA_AVALON_PIO_DIRECTION(SCL_BASE, 0x1); Clr_SDA; delay1us(); Set_SCL; delay1us(); Clr_SCL; delay1us(); } void Check_Ack(void) {int a=1; IOWR_ALTERA_AVALON_PIO_DIRECTION(SDA_BASE, 0x0); IOWR_ALTERA_AVALON_PIO_DIRECTION(SCL_BASE, 0x1); Clr_SCL; delay1us(); Set_SCL; delay1us(); while(a) { a=IORD_ALTERA_AVALON_PIO_DATA(SDA_BASE); delay1us(); printf("waiting ACK .a is %d\n",a); } delay1us(); printf("detected ACK\n"); Clr_SCL; delay1us(); }
void I2C_Nack(void) { IOWR_ALTERA_AVALON_PIO_DIRECTION(SDA_BASE, 0x1); IOWR_ALTERA_AVALON_PIO_DIRECTION(SCL_BASE, 0x1); Set_SDA; delay1us(); Set_SCL; delay1us(); Clr_SCL; delay1us(); } void I2C_Send_Byte(int d) { int i = 8; IOWR_ALTERA_AVALON_PIO_DIRECTION(SDA_BASE, 0x1); IOWR_ALTERA_AVALON_PIO_DIRECTION(SCL_BASE, 0x1); delay1us(); Clr_SDA; Clr_SCL; delay1us(); while( i-- ) { if (d&0x80) Set_SDA; else Clr_SDA; delay1us(); Set_SCL; delay1us(); Clr_SCL; delay1us(); Clr_SDA; Clr_SCL; delay1us(); d = d << 1; } delay1us(); } int I2C_Receive_Byte(void) { int retc,bitcnt; retc=0; IOWR_ALTERA_AVALON_PIO_DIRECTION(SDA_BASE, 0x0); IOWR_ALTERA_AVALON_PIO_DIRECTION(SCL_BASE, 0x1); delay1us(); for(bitcnt=0;bitcnt<8;bitcnt++) { Set_SCL; delay1ms(); retc=retc<<1; if((int)IORD_ALTERA_AVALON_PIO_DATA(SDA_BASE)) retc=retc+1; Clr_SCL; delay1ms(); } return(retc); } int main() {int data[500]={0}; int cnt; I2C_Start(); I2C_Send_Byte(0xb4); Check_Ack(); I2C_Send_Byte(0x00); Check_Ack(); I2C_Send_Byte(0x0a); Check_Ack(); I2C_Send_Byte(0x02); Check_Ack(); I2C_Send_Byte(0x39); Check_Ack(); I2C_Send_Byte(0x8d); Check_Ack(); I2C_Stop(); delay1ms(); I2C_Start(); I2C_Send_Byte(0xb6); Check_Ack(); I2C_Send_Byte(0x00); Check_Ack(); I2C_Send_Byte(0x0a); Check_Ack(); I2C_Send_Byte(0x02); Check_Ack(); for(cnt=0;cnt<2;cnt++) {data[cnt]=I2C_Receive_Byte(); printf("data=%x\n",data[cnt]); I2C_Ack(); } data[cnt+1]=I2C_Receive_Byte(); printf("data=%x\n",data[cnt+1]); I2C_Nack(); I2C_Stop(); }
