3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
| // generated by named-bootconf.pl
options {
directory "/var/named";
* If there is a firewall between you and nameservers you want
* to talk to, you might need to uncomment the query-source
* directive below. Previous versions of BIND always asked
* questions using port 53, but BIND 8.1 uses an unprivileged
* port by default.
// query-source address * port 53;
// a caching only nameserver config
zone "." {
type hint;
file "named.ca";
zone "0.0.127.in-addr.arpa" {
type master;
file "named.local";
zone "feixiang.com"{
type slave;
file "named.hosts";
masters {25.198.10.3;};
zone "198.25.in-addr.arpa"{
type slave;
file "named.rev";
cache . named.ca
secondary vbrew.com 25.198.10.3 named.hosts
secondary 198.25.in-addr.arpa 25.198.10.3 named.rev
primary 0.0.127.in-addr.arpa named.local
