aixlpar1 :/ # mmchlicense server --accept -N aixlpar1a,aixlpar2a
The following nodes will be designated as possessing GPFS server licenses:
aixlpar2a
aixlpar1a
mmchlicense:Command successfully completed
mmchlicenseropagating the cluster configuration data to all
affected nodes.This is an asynchronous process.
