启动ccs时会弹出如下对话框 CAN't initialize target cpu: error Ox80000200/-1073 fatal error during:Initialization,ocs, bad target silicon revision number please check your multi-processor configuration. the number of devices in the JTAG sCAN path must be correct for the silicon revision to be read or,you may have selected the wrong DSP device driver.
I/O Port=0 Board Name: C54xx XDS510 Emulator Cpu Name :CPU_1
有谁遇到过这样的问题吗? 请指教! 我用的是瑞泰 ICKTEK-5100USB V2.0仿真器 |
