RSCT 脚本RSCT LDAP 监控脚本 /opt/usrmgt/mon/checkldap1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
| #!/usr/bin/perl
$ITDS = "/opt/IBM/ldap/V6.3"; # LDAP Source Code Directory
$SUFFIX = "o=ORG,c=US"; # Your LDAP Suffix
$SOURCE = "/opt/usrmgt"; # User Management Code directory
$LOG = "$SOURCE/mon/CheckLDAP.log"; # Monitor Log file
$running = 0; # initialization of runtime vars
$userregerror = 0;
$usersyserror = 0;
$groupregerror = 0;
$LDAPH1 = "host1";
$LDAPH2 = "host2";
$LDAPI1 = "inst1";
$LDAPI2 = "inst2";
$LDAPP1 = 20389;
$LDAPP2 = 20389;
# Note that coding passwords in scripts is not recommended
# but you could replace this with your own password retrieval method
$pwd = "rootdnpwd"; # LDAP rootdn password
$arg = $ARGV[0]; # Testflag for command line execution
if ( $arg eq "offline" ) {
$termoutput = 1;
#Check status of the LDAP servers and fill the errormessage with the status information
for ( $i=1 ; $i<=2 ; $i++) {
$host = "LDAPH${i}";
$inst = "LDAPI${i}";
$port = "LDAPP${i}";
# Check for a valid root user entry in LDAP
$cmd = "$ITDS/bin/ldapsearch -h $$host -p $$port -D cn=rootdn -w '\?' -b $SUFFIX
uid=root userpassword";
# Use this method to parse the rootdn password, without risking that the
# password appears in the process list
#print("CMD = $cmd writing to $LOG.$$inst using $pwd\n");
open(IDS,"| $cmd > $LOG.$$inst 2>&1");
print(IDS "$pwd\n");
close(IDS);
open(IDS,"< $LOG.$$inst");
@ids = <IDS>;
close(IDS);
chomp(@ids);
shift(@ids);
#unlink("$LOG");
if ( $#ids == 1 ) {
foreach $line (@ids) {
#print("LINE = $line\n");
if ( $line =~ /userpassword/ ) {
@row = split("=",$line);
if ( $row[1] =~ /crypt/ ) {
$running = 1;
$errormessage .= "# $$inst,$$port,$$host=1 ";
} else {
$errormessage .= "# $$inst,$$port,$$host=2 '";
} else {
$errormessage .= "# $$inst,$$port,$$host=0 ";
# Check status of the registry and SYSTEM parameters in /etc/security/user and group
open(SEC,"/usr/bin/lssec -c -f /etc/security/user -s default -a registry -a SYSTEM |");
@sec = <SEC>;
close(SEC);
chomp(@sec);
foreach $line (@sec) {
if ( $line =~ /^default/ ) {
@row = split(":",$line);
# The second field holds the registry value
if ( $row[1] eq "LDAP" ) {
$userregldapset = 1;
} elsif ( $row[1] eq "files" ) {
$userregldapset = 0;
} else {
$userregerror = 1;
$errormessage .= "# userreg=$row[1];";
# The third field holds the SYSTEM value
if ( $row[2] eq "\"LDAP or compat\"" ) {
$usersysldapset = $running;
} else {
$usersyserror = 1;
$row[2] =~ s/"//g;
$errormessage .= "SYSTEM='$row[2]';";
open(SEC,"/usr/bin/lssec -c -f /etc/security/group -s default -a registry |");
@sec = <SEC>;
close(SEC);
chomp(@sec);
$line =~ s/"//g;
$groupregldapset = 1;
$groupregldapset = 0;
} else {
$groupregerror = 1;
$errormessage .= "groupreg='$row[1]'";
$action = 0;
if ( $running ) {
if ( not ${userregldapset} || not ${usersysldapset} || not ${groupregldapset} ) {
$action = 1;
} else {
if ( ${userregldapset} || ${usersysldapset} || ${groupregldapset} ) {
$action = 1;
if ( $groupregerror || $userregerror ) {
$action = 1;
if ( $userregerror || $usersyserror || $groupregerror ) {
$actionstring = "-${running}${userregerror}${usersyserror}${groupregerror}"
} else {
$actionstring = "${running}${userregldapset}${usersysldapset}${groupregldapset}"
$errormessage = "$actionstring $errormessage";
if ( $termoutput ) {
print("$running\n");
print("Int32=$action String=\"$errormessage\"\n");
} else {
print("Int32=$action String=\"$errormessage\"");
在 RSCT 通知后恢复脚本:/opt/usrmgt/mon/restartldapclient1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
92
93
94
95
96
97
98
99
100
101
102
103
104
| #!/usr/bin/perl
$reg{0} = "files"; # if $ldap is down
$reg{1} = "LDAP"; # if $ldap is up
$sys{0} = "LDAP or compat"; # if $ldap is down
$sys{1} = "LDAP or compat"; # if $ldap is up
$hostname = `/usr/bin/hostname -s`;
chomp($hostname);
if ( $ENV{ERRM_VALUE} ) { # Take ERRM_VALUE from notifier
$string = "$ENV{ERRM_VALUE}";
} else { # else simulate one for test
# Set a string fixed
# String = 0000 # host1-e0 NOT running # host2-e0 NOT running # User: registry is
'files' SYSTEM is 'LDAP or compat' , Group: registry is 'files'
# or get a string from IBM.Sensor
open(LSS,"/usr/sbin/rsct/bin/lssensor CheckLDAP |");
@lss = <LSS>;
close(LSS);
chomp(@lss);
foreach $line (@lss) {
$line =~ s/ *//;
if ( $line =~ /^String/ ) {
$string = $line;
$string =~ s/String = //;
print("STRINGLINE = $string\n");
@row = split("#",$string);
$ldapstatus = "$row[0]";
$ldapstatus =~ s/ //;
$group = "/etc/security/group";
$users = "/etc/security/user";
$debug = 1;
# 1=LDAP,2=UserReg,3=UserSys,4=GroupReg
if ( $ldapstatus =~ /^-/ ) {
$ldapstatus =~ s/^-//;
$ldap = substr($ldapstatus,0,1);
$userreg = substr($ldapstatus,1,1);
$usersys = substr($ldapstatus,2,1);
$groupreg = substr($ldapstatus,3,1);
setuserreg($reg{$ldap}) if ( $userreg );
setusersys($sys{$ldap}) if ( $usersys );
setgroupreg($reg{$ldap}) if ( $groupreg );
} else {
$ldap += 0;
$userreg += 0;
$usersys += 0;
$groupreg += 0;
if ( $ldapstatus eq "0000" || $ldapstatus eq "1111" ) {
#print("NO CHANGE NEEDED\n");
$debug = 0;
} else {
$doit = ${ldap}^${userreg} ;
setuserreg($reg{$ldap}) if ( $doit );
$doit = ${ldap}^${usersys} ;
setusersys($sys{$ldap}) if ( $doit );
$doit = ${ldap}^${groupreg} ;
setgroupreg($reg{$ldap}) if ( $doit );
if ( $userchange || $groupchange ) {
system("/usr/sbin/restart-secldapclntd");
sub setuserreg {
my $registry = $_[0];
$cmd = "/usr/bin/chsec -f $users -s default -a registry=$registry";
system("$cmd");
$userchange = 1;
sub setusersys {
my $SYSTEM = $_[0];
$cmd = "/usr/bin/chsec -f $users -s default -a SYSTEM=\"$SYSTEM\"";
system("$cmd");
$userchange = 1;
sub setgroupreg {
$cmd = "/usr/bin/chsec -f $group -s default -a registry=$registry";
system("$cmd");
$groupchange= 1;
