结合使用 Redux 和 Angular-4
历史组件的代码很长,所以我将它分为两个清单。该组件的模板如清单 10 所示。
清单 10. History 组件的模板          (app/components/history.component.ts)
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
import { Component } from '@angular/core';
@Component({
  selector: 'history',
  template: `
  <input type='range' #range
    style='cursor: pointer'
    min={1}
    (input)='setState(range.value)'
    [max]='maximum'
    [value]='value'/>
  <a href='#' style='text-decoration: none'
    (click)='previousState()'
    [innerHTML] = 'leftArrow'>
  </a>
    (click)='nextState()'
    [innerHTML] = 'rightArrow'>
  </a>
历史组件包含滑块和箭头按钮,它们控制应用程序的当前状态。同样地,模板标记将事件(确切地讲,是 click 和 input        事件)映射到组件方法。这些方法如清单 11 所示,其中包含历史组件的 TypeScript。
清单 11. History 组件的          TypeScript        (app/components/history.component.ts)
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
import { gotoState, redo, undo } from '../../actions';
import stateHistory from '../../statehistory';
import store from '../../store';
export default class History {
  private leftArrow: string;
  private rightArrow: string;
  private stateHistory: any;
  private topic: string;
  private unsubscribe: any;
  private value: number;
  private maximum: number;
  constructor() {
    this.leftArrow = '&larr;';
    this.rightArrow = '&rarr;';
    this.stateHistory = stateHistory;
    this.unsubscribe = store.subscribe(() => {
      this.topic = store.getState().topic;
      this.maximum = this.max();
      this.value = this.val();
  setState(stateIndex) {
    store.dispatch(gotoState(stateIndex));
  previousState() {
    store.dispatch(undo());
  nextState() {
    store.dispatch(redo());
  val() {
    return this.stateHistory.past ? this.stateHistory.past.length : 0;
  max() {
    return (this.stateHistory.past    ? this.stateHistory.past.length   : 0) +
           (this.stateHistory.present ? 1 : 0)             +
           (this.stateHistory.future  ? this.stateHistory.future.length : 0) - 1;
  ngOnDestroy() {
    this.unsubscribe();
像我目前讨论的其他 Angular 组件一样,历史组件将会订阅 Redux 存储,并在状态更改时更新其 topic、maximum        和 value 属性。
历史组件使用 stateHistory 对象配置它的滑块。像 reducer、操作和存储一样,stateHistory        对象与应用程序的 React 版本相同。请参阅 “” 了解 stateHistory 对象的实现。
Books 组件如清单 12 所示。
清单 12. Books 组件        (app/components/books.component.ts)
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
import { trigger, state, style, transition, animate } from '@angular/core';
import Book from './book.component';
@Component({
  selector: 'books',
  template: `
    <div *ngIf='status === "Fetching..."'
      style='width: 100%; padding: 20px; text-align: center'>
      <img src="../images/spinner.gif" role="presentation" />
    </div>
    <div *ngIf='displayMode === "LIST"' style='width: 100%; padding: 20px;'>
      <ul>
        <li *ngFor='let book of books'>
          <book [item]='book'
                [displayMode]='displayMode'></book>
        </li>
      </ul>
    </div>
    <div *ngIf='displayMode === "THUMBNAIL"' style='padding: 20px;'>
      <book *ngFor='let book of books'
        [item]='book'
      </book>
    </div>
export default class Books {
  private books: Array<Book>;
  private displayMode: string;
  private status: string;
  constructor() {
      const state = store.getState();
      this.books = state.books;
      this.displayMode = state.displayMode;
      this.status = state.currentStatus;
  ngOnDestroy() {
    this.unsubscribe();
如果应用程序的当前状态为 Fetching...,Books 组件将显示一个下拉列表部件。该组件也会迭代图书列表,创建 book          元素。Books 组件通过订阅 Redux 存储来同步其表示状态的属性。
