NUCLEO-F031K6试用]MDK寄存器版:1、点灯
程序效果需要在仿真的时候才能出现,请在Debug模式下设置断电后,单步调试实现LED指示灯的亮灭。
代码如下:
mian.c
#include "stm32f0xx.h"#include "sys.h"#include "led.h"int main(void){ SystemCoreClockConfigure(); SystemCoreClockUpdate(); led_init(); while(1) { GPIOB->BSRR = 0x1 << 3; GPIOB->BRR = 0x1 << 3; }}
led.c
#include "led.h"int led_init(void){ //PB3 RCC->AHBENR |= 0x00040000; GPIOB->MODER &= ~(0x3 << 6); GPIOB->MODER |= 0x1 << 6; GPIOB->OTYPER &= ~(0x1 << 3); GPIOB->OSPEEDR |= 0x3 << 6; GPIOB->PUPDR &= ~(0x3 << 6); GPIOB->AFR[0] |= 0x3 << (3 * 4); return 0;}
sys.c
#include "sys.h"/*---------------------------------------------------------------------------- * SystemCoreClockConfigure: configure SystemCoreClock using HSI *----------------------------------------------------------------------------*/void SystemCoreClockConfigure(void) { RCC->CR |= ((uint32_t)RCC_CR_HSION); // Enable HSI while ((RCC->CR & RCC_CR_HSIRDY) == 0); // Wait for HSI Ready RCC->CFGR = RCC_CFGR_SW_HSI; // HSI is system clock while ((RCC->CFGR & RCC_CFGR_SWS) != RCC_CFGR_SWS_HSI); // Wait for HSI used as system clock FLASH->ACR = FLASH_ACR_PRFTBE; // Enable Prefetch Buffer FLASH->ACR |= FLASH_ACR_LATENCY; // Flash 1 wait state RCC->CFGR |= RCC_CFGR_HPRE_DIV1; // HCLK = SYSCLK RCC->CFGR |= RCC_CFGR_PPRE_DIV1; // PCLK = HCLK RCC->CR &= ~RCC_CR_PLLON; // Disable PLL // PLL configuration: = HSI/2 * 12 = 48 MHz RCC->CFGR &= ~(RCC_CFGR_PLLSRC | RCC_CFGR_PLLXTPRE | RCC_CFGR_PLLMULL); RCC->CFGR |= (RCC_CFGR_PLLSRC_HSI_Div2 | RCC_CFGR_PLLMULL12); RCC->CR |= RCC_CR_PLLON; // Enable PLL while((RCC->CR & RCC_CR_PLLRDY) == 0) __NOP(); // Wait till PLL is ready RCC->CFGR &= ~RCC_CFGR_SW; // Select PLL as system clock source RCC->CFGR |= RCC_CFGR_SW_PLL; while ((RCC->CFGR & RCC_CFGR_SWS) != RCC_CFGR_SWS_PLL); // Wait till PLL is system clock src} |
