Reading System ID at address 0x00401898: does not match ID value does not match: read 0x997AD0CE; expected 0xD5D175D6 Timestamp value does not match: image on board is older than expected Read timestamp 17:33:32 2007/07/10; expected 23:18:40 2007/08/15 The software you are downloading may not run on the system which is currently configured into the device. Please download the correct SOF or recompile. Restarting target processor 有人知道這可能是怎麼回事嗎? ============================================================================== 我拿以前在別台PC上做好的project直接下到fpga是沒問題的 可是只要重新compilation之後就會出現這個問題 我想...是不是tool本身出問題的機會比較大?
[此贴子已经被作者于2007-8-16 19:50:51编辑过] |
