3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
92
93
94
95
96
97
98
99
100
101
| /* boy.c */
#include "boy.h"
enum { BOY_BORN, LAST_SIGNAL };
static gint boy_signals[LAST_SIGNAL] = { 0 };
static void boy_cry (void);
static void boy_born(void);
static void boy_init(Boy *boy);
static void boy_class_init(BoyClass *boyclass);
GType boy_get_type(void)
static GType boy_type = 0;
if(!boy_type)
static const GTypeInfo boy_info = {
sizeof(BoyClass),
NULL,NULL,
(GClassInitFunc)boy_class_init,
NULL,NULL,
sizeof(Boy),
0,
(GInstanceInitFunc)boy_init
boy_type = g_type_register_static(G_TYPE_OBJECT,"Boy",&boy_info,0);
return boy_type;
boy->age = 0;
boy->name = "none";
boy->cry = boy_cry;
boyclass->boy_born = boy_born;
boy_signals[BOY_BORN] = g_signal_new("boy_born",
BOY_TYPE,
G_SIGNAL_RUN_FIRST,
G_STRUCT_OFFSET(BoyClass,boy_born),
NULL,NULL,
g_cclosure_marshal_VOID__VOID,
G_TYPE_NONE, 0, NULL);
Boy *boy_new(void)
Boy *boy;
boy = g_object_new(BOY_TYPE, NULL);
g_signal_emit(boy,boy_signals[BOY_BORN],0);
return boy;
int boy_get_age(Boy *boy)
return boy->age;
void boy_set_age(Boy *boy, int age)
boy->age = age;
char *boy_get_name(Boy *boy)
return boy->name;
void boy_set_name(Boy *boy, char *name)
boy->name = name;
Boy* boy_new_with_name(gchar *name)
Boy* boy;
boy = boy_new();
boy_set_name(boy, name);
return boy;
Boy* boy_new_with_age(gint age)
Boy* boy;
boy = boy_new();
boy_set_age(boy, age);
return boy;
Boy *boy_new_with_name_and_age(gchar *name, gint age)
Boy *boy;
boy = boy_new();
boy_set_name(boy,name);
boy_set_age(boy,age);
return boy;
g_print("The Boy is crying ......\n");
g_print("Message : A boy was born .\n");
void boy_info(Boy *boy)
g_print("The Boy name is %s\n", boy->name);
g_print("The Boy age is %d\n", boy->age);
