请教高手SOPC BUILDER中validation急用
![Rank: 2](images/default/star_level2.gif)
请教大虾: 我在用QuartusII 7.1中的SOPC BUILDER创建一个简单的片上系统时,点击generate报错如下: Generation skipped because the system has validation errors. 请问如何解决? 我的破解文件是在论坛中找的,在作一般的程序时可以生成.sof和.pof文件。 急用!在此提前谢谢各位大虾! |
Generation skipped because the system has validation errors 光是这样的信息无法判断是什么的问题,需要更多的信息。 |
这个版主不太冷
我的中电网博客:http://blog.chinaecnet.com/u/20/index.htm |
谢谢!我是按照一个示例逐步添加各组件的,但在选项卡上只有System contents和System generation,没有出现示例中的Nios II More "cup_0" Settings.点击Generate后在System generation选项卡下出现以下信息: Info: cfi_flash: Flash memory capacity: 2.0 MBytes (2097152 bytes). To Do: cpu: No reset vector has been specified for this CPU. Please parameterize the CPU to resolve this issue To Do: cpu: No exception vector has been specified for this CPU. Please parameterize the CPU to resolve this issue Error:Generation skipped because the system has validation errors. 请大虾指点迷津!
[此贴子已经被作者于2007-8-21 11:03:18编辑过] |
以下是我用Nois II7.1自带的示例工程NiosII_cyclone_1c20_low_cost.qpf用SOPC BUILDER 打开后点击Generate出现的信息: "d:/altera/quartus71/quartus//bin/jre/bin/java.exe" -Xmx256M -classpath "d:/altera/quartus71/quartus//sopc_builder/bin/sopc_builder.jar;d:/altera/quartus71/quartus//sopc_builder/bin/PinAssigner.jar;d:/altera/quartus71/quartus//sopc_builder/bin/sopc_wizard.jar;d:/altera/quartus71/quartus//sopc_builder/bin/jptf.jar" sopc_builder.sopc_builder -d"d:/altera/quartus71/quartus//sopc_builder" -projectnameNiosII_cyclone_1c20_low_cost.qpf -projectpathF:/myproj/low_cost --no_splash --refresh F:/myproj/low_cost/NiosII_cyclone_1c20_low_cost.v --quartus_dir="d:/altera/quartus71/quartus/" --sopc_perl="d:/altera/quartus71/quartus//bin/perl" --sopc_lib_path="F:\myproj\low_cost+d:\altera\quartus71\quartus\common\librarian\factories+d:\altera\quartus71\quartus\sopc_builder\model\lib+" Executing: d:/altera/quartus71/quartus//sopc_builder/bin/sopc_builder --legacy --generate F:/myproj/low_cost/NiosII_cyclone_1c20_low_cost.ptf
Info: Starting generation...
"d:/altera/quartus71/quartus//bin/jre/bin/java.exe" -Xmx256M -classpath "d:/altera/quartus71/quartus//sopc_builder/bin/sopc_builder.jar;d:/altera/quartus71/quartus//sopc_builder/bin/PinAssigner.jar;d:/altera/quartus71/quartus//sopc_builder/bin/sopc_wizard.jar;d:/altera/quartus71/quartus//sopc_builder/bin/jptf.jar" sopc_builder.sopc_builder -d"d:/altera/quartus71/quartus//sopc_builder" -projectnameNiosII_cyclone_1c20_low_cost.qpf -projectpathF:/myproj/low_cost --generate F:/myproj/low_cost/NiosII_cyclone_1c20_low_cost.v --quartus_dir="d:/altera/quartus71/quartus/" --sopc_perl="d:/altera/quartus71/quartus//bin/perl" --sopc_lib_path="F:\myproj\low_cost+d:\altera\quartus71\quartus\common\librarian\factories+d:\altera\quartus71\quartus\sopc_builder\model\lib+"
Error: One or more components could not be located (altera_nios2). Check Global User Libraries under Tools->Options... in Quartus II.
Error: System generation failed.
请大虾帮忙解决!急用,谢谢! |
我也是遇到了这种问题?好郁闷!!不知哪位高手能帮帮我。 |
![Rank: 3](images/default/star_level2.gif) ![Rank: 3](images/default/star_level1.gif)
7.1版本与6.0不同,配置之后还得配置复位地址与异常地址,它不像6.0一像自动选择 另外:根据Error: One or more components could not be located (altera_nios2). Check Global User Libraries under Tools->Options... in Quartus II.你应该没有装IP library,把它装并破解好应该可以解决了,这个问题我也遇到过
[此贴子已经被作者于2008-5-15 15:06:43编辑过] |
