make -s all Creating generated.x... Aug 28, 2007 9:45:06 PM - (??) generate: java.lang.IllegalStateException: java.lang.IllegalStateException: java.lang.NumberFormatException: For input string: "N/A" WARNING: Default charset GBK not supported, using ISO-8859-1 instead make[1]: *** [system_description/../obj/generated.x-t] Error 1 make: *** [system_project] Error 2 Build completed
编译时提示 请大虾指点迷津!非常感谢 !!Quartus II 5.0 & nios2 5.0.1
[此贴子已经被作者于2007-9-1 16:16:39编辑过] |
